2011 R56 Mini Cooper S Rear Clunking Noise
I recently picked up 2011 mini cooper s Manual with 104k miles. I noticed there is clunking noise from rear while driving at low speed like 5-25 MPH. It doesn't make any noise at high speed though.
It has aftermarket NM motoring rear sway bar. I thought It could be rear sway bar bushing or stabilizer links since It does seem like those two make clunking noise when I checked on Youtube.
I went to shop for oil change and asked them to check and they said it seemed like it works fine. what else it could be?
Just curious. If the NM links were installed, I would blame them. That style is notorious for being noisy, rattles, and clunks. They are stiffer, but they will make noises.
That being eliminated, possible suspects for rear end noises would be: end links, shocks, shock mounts, sway bar bushings. A friend of mine had a rear hatch latch that would clunk and make noises... Could be a loose exhaust hanger...
(FYI: noises and rattles are VERY difficult to diagnose over the interwebs. Best to find someone to ride along with you that can help find where it 'might' be coming from)
Just to help diagnose... try to listen for the clunk, and pay attention to what the car is doing when it clunks. For instance, if it clunks when driving diagonally over a speed bump or into a driveway transition, it could be sway bar bushing or end link related. If it clunks when going straight and hitting a sharp impact, like a pot hole, it could be shock related.
I noticed there were some little grease on sway bar bushing while car was lifted so I'm going to go for sway bar bushing. Yes it clunks when driving diagonally over a speed bump or into driveway transition.
Do you think I have to go for this one below?
https://nm-eng.com/products/nm-eng-a...2mm-nmbku62506
Thank you
I suggest you consider bushing replacement. I had a very hard time identifying the cause of a rattle in the rear of the '07 MCS. It only became apparent that it was the RSB bushings when I pulled them.
Both front and rear bushings have shown a notable tendency to wear out on my two Minis.
Oldelmo (09-13-2023)
Rear springs need to be orientated correctly, there is a mark on the spring mount to indicate where end of spring coil should end. If spring is not positioned right it will cause an odd thump from the rear. I replaced rear struts and missed the mark on one side, this may not apply in your case but it's easy to check if it's on a lift.
So I've also been having the rear clunking....kind of a hollow bang if that makes sense. I followed the path of thinking it was the rear hatch latch and I've been adjusting it after I bought a new one thinking I was getting improvement on some days and not on others. I then found this thread and decided that it might be something with the rear suspension. I just lifted the car and put it on jacks just now. Everything is tight. Background on the car for reference:
-2013 JCW
-Lowered about an inch and a half on KW Street Comfort Coils
-NM Engineering RSB
-WMW adjustable end links
-H-Sport Adjustable Rear Camber Links
-Aligned to factory specs
Last week I also greased the sway bar bushings with Energy Suspension grease. Terrible to work with but amazing stuff. So, I started there and low and behold, when I slide the sway bar back and forth through the bushings (across the lateral dimension of the car), it bangs that hollow bang against the stops on the sway bar itself and the bushing housing. Like a thud. So I'm assuming that every time I go over an uneven bump and one wheel is lifted higher than the other, it pushes the end link which in turn pushes the sway bar against that stop.
Sound reasonable? And if so, how the hell do I stop that banging?
Thanks!
-2013 JCW
-NM Engineering RSB
Thanks!
2ndof2
07-17-2021 01:05 PM
geekd4d
R60/R61 Stock Problems/Issues
04-14-2020 07:13 PM
BlueBomberRC83
05-09-2014 09:46 AM
