How to access pistons
I have had an 07 mini justa (N12) for a little over a year, bought for my granddaughter. I thought she was 16 in '21, naa, only 15. So I've garage kept her car and gone through it. Many electrical bugs cleared up (Thank you Minitobe). It was burning a little oil and of course at 107K miles, needed some work on the valves seats. The engine is removed, not a bad deal.
Here is my question:
I've pulled off the cylinder head and several of the valves are really tired. I plan on buying a rebuilt cylinder head. Pretty good deal
The short block, to my surprise is in excellent condition. Top of pistons look great, a little carbon deposit, but walls are smooth. I will certainly replace the rings at this point, However, the Bentley Book doesn't show anything on accessing the main engine block.
? Do I remove the lower unit above (or underneath) the oil pump?
? Better yet, is there a link available to a exploded view, breakdown?
Thanks for your help. This site has allowed me to correct a mistake I made when I purchased this car. Cute, is never a good reason to buy a car. I have tried looking up this info from past threads. However, my queries always show 50 things I'm not searching for. I'm sure there is a way, but I am sucking air on search information.
Regards,
Briscoe
Regards,
Briscoe
930 Engineering (12-19-2021)
![](https://cimg9.ibsrv.net/gimg/www.northamericanmotoring.com-vbulletin/800x560/503203_a94389f22c99b3d1aa68863e8c6c9eeb2d8e9962.jpg)
You'll find several part numbers and alternative parts in some cases you might need here:
https://www.leebmann24.de/bmw-ersatz...31&og=01&hg=11
It's German but quite easy to understand from the pictures. Just google the part numbers afterwards.
For example:
piston rings OE BMW:
11257566479
piston rings MAHLE:
081 RS 00104 0N0
![](https://cimg9.ibsrv.net/gimg/www.northamericanmotoring.com-vbulletin/800x560/192106_bf6c717d1eeab88188cfc04db5f5769ec5be447a.jpg)
N12 pistons and rings are still easily available both from BMW and Mahle via every European
BMW dealership and hundreds of independent vendors dealing with Mahle parts respectively:
https://www.leebmann24.de/bmw-ersatz...=11&bt=11_3921
Hardly a issue.
Hardly a issue.
ICallMyCarKate
07-11-2016 07:24 AM
