front window panel/column cracked???....help please
Old 01-13-2005 | 11:24 AM
Panganiban's Avatar
Panganiban
Hey guys...Just noticed yesterday that the front window column/panel is cracked. Have no idea how it happened. Has anyone ever had problems completely shutting the door due to the window not moving the quarter inch it is suppose to when opening and closing? One day I tried closing the door and it wouldn't shut. I had to roll down the window. I'm thinking this may have caused the column to crack. Any explanations anyone? Is this something that may required to be repaired right away? How much would this cost or would this be covered in the warranty? Input anyone?
Old 01-13-2005 | 11:40 AM
buzzy's Avatar
buzzy
If you are talking about the outside A-Pillar cover, it should be replaced under warranty.
I've heard about them falling off at high speed so might be somthing to get replaced soon if you can.
Luke
Old 01-13-2005 | 12:13 PM
Panganiban's Avatar
Panganiban
Thanks...Still not sure if that is the A-Pillar cover. I'll try to put pics up sometime soon so you guys can see.
Old 01-13-2005 | 09:16 PM
gone_motoring's Avatar
gone_motoring
Does it look like the picture in this earlier post?:
https://www.northamericanmotoring.co...5&postcount=28
That's the A-pillar that is cracked in the photo in the link
Old 01-14-2005 | 10:40 AM
Panganiban's Avatar
Panganiban
Yup...That's exactly it. Ironic thing is, the crack is similar and it happened the same way it did to that Cooper. When I went to shut the door, the window didn't dip down and so it wouldn't shut. Correct me if I'm wrong, but this will be covered by Mini right??? Also, who should I contact regarding this problem, the service department or Mini USA?
Old 01-16-2005 | 07:49 PM
Morefun's Avatar
Morefun
Happened to me with my May '04 build MCS. It was easier to order the $35 replacement part from Cassic Mini than to do a four hour RT to the dealer. Push back the weather seal, remove three screws and pop it off. Installation is the reverse. Seems to be a random occurance. Probably won't be the last one.
Cheers,
Old 01-24-2005 | 02:33 PM
BMWNA's Avatar
BMWNA
Re: front window panel/column cracked???....help please
I’m with MINI USA. I’m sorry to read about this problem with your window. We are here to work with you and your Dealer. If you need our assistance, please phone us at (866) ASK MINI or email us at MINI.Assistance@askMINIUSA.COM and mention Reference # 200502400671 so that we can help you more efficiently.
Old 01-24-2005 | 02:43 PM
JFEINSTEIN's Avatar
JFEINSTEIN
I've had to replace the window regulator twice ...... window non-dipping problem ... both covered by warranty ... A pilliar cracked ( unrelated ) also covered by warranty.
Old 01-24-2005 | 06:36 PM
edhill's Avatar
edhill
Both pillar covers on my '04 broke withing the past 10 days. The upper rear-most quadrants cracked within a few millimeters of being mirror images, from the center of th top to just above the top screw hole. The cracked area is about 2.5 by 4 inches. Never happened on my '02 during the time I owned it.
No trips on bad roads, still commuting on the same relative smooth roads. No wild temperature swings. Anyone know what may cause it, and how to keep it from happening?
07-16-2020 01:54 PM
woodstudio
03-15-2020 09:28 AM
NYXF56JCW
01-22-2016 06:32 AM
08-19-2015 01:51 PM
FLYM1N1
08-15-2015 12:20 PM
