Is it ok to just replace the WP pulley?
Old 03-03-2022 | 08:34 PM
masterchodeswag's Avatar
masterchodeswag
I have an R56 1.6 base non-s. The car is not over heating but i have been told that the waterpump pulley needs to be replaced plus it sounds like ****. is it ok if i just replace the pulley and not the whole pump? i dont want to have the extra cost of anti-freeze if i dont have to right now. i am doing a whole timing chain replace come May-ish when it finally warms up enough in Minnesota in case it takes me a couple days and plan on doing the water pump then.
Old 03-04-2022 | 12:38 AM
giorgos's Avatar
giorgos
Since it is (very) unlikely that the friction wheel pulley's surface is damaged (and could thus damage the new water pump pulley), I see no harm in replacing the water pump pulley only.
And since you are planning on changing the water pump pulley yourself: Have you verified yourself that it is indeed in need of replacement (i.e. its contact surface is unevenely worn and/or pieces are missing)? A worn/damaged serpentine belt causes similar noise.
Even residue/dirt inside the crank pulley's tracks can cause a knocking noise.
Old 03-04-2022 | 04:38 PM
masterchodeswag
Thanks man! im going to check it out before i start (hopefully this wknd)
theDonVon
11-27-2019 08:06 PM
the whine is so divine
04-24-2008 11:47 AM
guitfiddler
28
12-23-2007 09:35 PM
MarioKart
11-30-2006 09:29 AM
CooperSdriver
08-25-2003 06:33 AM
