Pop Pop Pop...?
Pop Pop Pop...?
Had my MCS '05 for a month, (live in Grand Cayman). After the first week, I noticed that when I turned it on first thing in the morning, the rev's would drop very low, and it felt like it would stall. Then it would jump back up and would be fine for the rest of the day, unless it sat for over eight hours, then it would have the same problem. The dealer reprogrammed it but did not do a thing. Suggested it was the gas I was using, I switched to Esso (high octane) from Texaco and that problem stopped. However, whenever I'm in first or second, the exhaust makes a popping sound when I accelerate, like tiny back firing, sounds like "pop pop pop". Don't know much in regard to mechanics, and dealer isn't much help either. Any ideas what it is? Could it be the fuel?
Thanks,
MB
Thanks,
MB
The "pop, pop, pop..." is there by design. MINI provided a more aggressive exhaust note on the 05's. You can search for "backfire" or similar terms and see that others have asked the same thing.
In fact, MINI marketing includes the following in their marketing material:
"The Crackling Noise.
When motoring in your convertible, you'll probably hear an aggressive sort of crackling or popping noise coming from the exhaust. That's actually been built in on purpose. Back in the day, the classic rally Minis made that type of sound as they raced through Europe. We thought it was only fitting to keep it."
While the text says "convertible" it applies to all 05's.
I used to have an accord with a Dc Sport exhaust on it and it was sorta bumble bee-ish and it is really the quietest exhaust so with that being said I do not like the loud obnoxius sound of most exhaust's these day but the factory 05 MCS is awesome, It is a little rumbly but not too loud becuase I would hate to be running around sounding like a teeanger at 32 years old .
Originally Posted by apexer
Note he said Pops when accelerates. You will hear a burble between shifts and when decelerating but, I don't think you should hear Popping when on the gas.
Originally Posted by DoubleNick
YEOW! I will be 62 and love my Magna Flow. After straight pipes on my '01 Vette--my MCS still sounds tame. Maybe, because I was a teenager back in the 50's and the early 60's I got use to hearing cars(hot rods) that sounded like cars. Have fun. Nick
When my 05 was new - it has almost 11k on it now - it too started with some difficulty; almost stalled, but with a blip from the throttle all was just fine. This phenomenon has completely disappeared, for whatever reason. The car sits in an unheated garage overnight, but even when temps get down to around 20 degrees f, the car starts without hesitation and idles just fine.
The pop-pop-pop is part of any off-throttle position sound 'designed in' by BMW/Mini. It is supposed to sound like a motorcycle when the throttle is closed. However, if you are experiencing a noise similar to this while accelerating as you state, it might be ping-ping-ping, in which case I'd make sure you are using the highest octane gasoline available.
MINI Stupor
10-01-2015 12:36 PM
patsum
11
09-30-2015 03:20 PM
