How do I disconnect the brake booster vac line
Press the brake pedal a few times until it becomes hard to push - this alleviates any residual vacuum and will make disconnecting the line easier.
In your pic, squeeze the sides of the fitting while you pull it apart.
edit: sometimes it helps to push the line into the fitting, then squeeze, then pull.
dianna912
10-16-2008 02:26 PM
