R53 Passenger Outer CV Boot Keeps Failing
Old 06-30-2022, 02:51 PM
N8n82012's Avatar
N8n82012
N8n82012 is offline
Hi all, as the title suggests, my passenger cv boot is torn yet again. This is the third axle that I’ve put into the car, and I’d like to find a solution. If anyone has experienced something similar please pass on the wisdom.
The car is lowered on a set of race land coil overs, however the problem has been around since before the lowering.
Thanks,
Nathan Mayer
Old 07-01-2022, 11:51 AM
mrbean's Avatar
mrbean
mrbean is offline
Are you replacing the entire axle each time or just the boot?
I had the same issue many many years ago on an old VW I had at the time. I never got to the bottom of it.
Old 07-02-2022, 05:42 PM
JakePapageorge's Avatar
JakePapageorge
JakePapageorge is offline
In addition to Mrbean's question, where on the boot is it splitting? At or near the clamps or in the center bellows?
Old 07-28-2022, 12:34 PM
N8n82012's Avatar
N8n82012
N8n82012 is offline
Yes, I’ve replaced the entire axle because, since I had realized far too late. It’s tearing right in the center of the bellows in a circular fashion. Almost appears as if the boot is rubbing on itself?
would love to get to the bottom of this.
thanks
Old 08-11-2022, 02:39 PM
khnitz's Avatar
khnitz
khnitz is offline
I recall reading elsewhere that if the engine mounts are bad, this could also cause wear (or maybe I'm thinking of advice for another one of my vehicles).
ijourneaux
07-26-2020 04:40 PM
bergie33
09-22-2018 07:44 AM
chicohuahua
04-15-2015 08:07 AM
MiniMerkel
08-08-2014 10:17 AM
heavy18
11-10-2013 02:32 PM
Quick Reply: R53 Passenger Outer CV Boot Keeps Failing
