Fuel Pressure Regulator Vacuum pipe
Old 07-23-2022, 06:01 PM
Daftlad's Avatar
Daftlad
Daftlad is offline
This one (item #13 below) doesn't like to stay connected to the fitting underneath the supercharger discharge / intercooler intake horn. Rather than replace it with a new one and then wait for the same problem to occur down the road, has anyone come up with a better solution? Can it be 'glued' on to the fitting as a temporary measure, say with aviation gasket maker (the sticky brown stuff from Permatex), or can a length of ordinary vacuum line simply be cut to size and used in lieu of it? Any reason it has to be a hard plastic line?
https://www.realoem.com/bmw/enUS/sho...diagId=13_0978
Old 07-24-2022, 10:47 AM
mrbean's Avatar
mrbean
mrbean is offline
In the 19 years I've owned my R53 that hose has never detached itself.
Just replace it and it will be fine.
The following 2 users liked this post by mrbean:
Daftlad (07-24-2022), ghostwrench (07-31-2022)
Old 07-29-2022, 05:30 PM
jjcsnlynn's Avatar
jjcsnlynn
jjcsnlynn is offline
Just go buy some flexible vacuum hose and connect both ends. Make sure it’s vacuum hose so it won’t collapse.
speedman
03-02-2020 04:18 AM
tej98
15
02-12-2020 08:58 PM
wrigdust
06-20-2018 02:36 PM
dandennis123
05-17-2013 08:01 AM
gibatheviking
Electrical
07-27-2007 01:20 PM
Quick Reply: Fuel Pressure Regulator Vacuum pipe
