Clunking sounds from the rear - most of the bushings have been replaced?
Recently the rear end of my car has developed some clunking noises. It really sounds like bad bushings. It is most obvious when I'm turning into say, an inclined driveway, or turning on any "humps" on the road at low speeds. My car has about 125k miles on it and so far at the rear I've recently replaced:
Rear sway bar bushings
Rear sway bar endlinks
Struts
Upper strut mount bushings
What am I missing? I am suspecting the rear trailing arm bushings are worn but I'm wondering if there's anything else I should take a look at first.
Struts
Definitely double check all of your fasteners back there. Might as well look at the exhaust hangars while you're at it. Any suspension mods? Recently get new wheels or tires? Had a similar thing happening on a friends CRX recently and it turned out to be a wheel weight that was catching on the rear brake only at certain speeds with the suspension under load at the right angle. OEM or aftermarket struts? I'd for sure start by checking over the work you just did.
R50/53 Clunk in rear, need ideas
davisflyer
25
02-17-2013 05:44 PM
