Axle Installation
Axle Installation
Hello everyone.
I was having a leak at my outer cv seal on the passenger side. When I went to remove the axle I noticed about a quarter inch gap between the dust shield and where the axle spindle goes into the transmission. I thought maybe something was wrong with the axles so I got the cardone. One at RockAuto. Installed it yesterday and there's still a gap between the dust shield and the transmission. I'll attach a picture below. Is this something I should be concerned about? Is there anything else I should be looking at as to why they're such a gap? I would think the axle should push all the way in until it stops, but if I do that the carrier bearing mount does not line up correctly. When driving there's no vibrations or weird sounds so it doesn't seem to affect performance. Drivability but it just seems kind of odd that it doesn't push all the way in.
I did watch mod mini video on it and his pushes all the way in. Maybe I'm just being overly cautious. Open to suggestions.
Axle not seeming to push all the way in so the dust shield meets the trans.
It should push all the way in.
I just replaced mine, there's a spring clip on the end that works as a detente. It might be that Cardone spring clip is a little stiff, but even the axles I bought I had to wiggle and thump on a bit to get that end to click in fully.
In my case, when I had mine apart my strut and hub were disconnected from the lower control arm, so i put the outer end in the hub and could just yank yank yank the hub inwards until it clicked in. But if yours is already fully reassembled you might need to try a strap wrench (not sure it'll grip it enough) or loosen that hub nut and tap it with a hammer.
That whole black assembly the inside boot is tied to allows the axle to move fully, there's basically three big grooves in it - so I'm not surprised you can drive fine, but there's a risk that the axle could begin rubbing the inside of that black cup, and a risk the unsecured axle end could work it's way out. So I'd say it's worth the effort to make sure its clicked in.
bratling (08-24-2022)
Thanks for the response.
I can push it all the way in, but then the mount for the carrier bearing on the shaft no longer lines up with the block and I can't mount it. Does that make sense? It's between 1/4 and 1/2 inch off. Everything else seems to line up OK, I just can't push it in any futher, doing so I can't line up the mount for the 3 bolts. Both the old and the new axle have that issue.
The bearing on the axle shaft shouldn't be moved correct?
For the passenger side axel, it will only go in so far due to the intermediate bearing support bracket. As long as it engages with the differential and the bearing bracket mounts up, the axel is in. Also, as long as there is a seal on the gearbox case, that dust shield is just a deterrent
So the.gap between the trans and lip of the axle where it would stop is ok? Seems kind of weird to not push all the way in. I watched mod minis video and his engages all the way in.
Either way I returned the axle and will try to get an OEM. I'm reading too many horror stories on the aftermarket axles and them not lining up right.
geolemon (08-23-2022)
I wouldn't feel right if it didn't click in either.
I didn't buy an OEM axle, I used the exact brand in the Mod Mini video... Mine clicked all the way in on replacement.
I agree yours seems off - maybe one axle was too short - but that's a LOT too short. Definitely the right move to return it if it didn't fit.
Just for clarification, the left side axel (driver’s side in the US) clips into the transmission with the circlip on the axel splines. The right side axel (passenger side in the US) does not use the little clip on the end of the axel. The passenger side axel is held in place by the bearing bracket that mounts to the engine block. So, as long as the axel engages with the differential and the bearing block mounts to the engine, the axel is secure. Also, as long as the gearbox has an axel seal and doesn’t leak oil, you shouldn’t have any issue with gearbox contamination. That “dust finger” is a secondary protection for the gearbox seal.
I know the carrier housing is what holds the axle in place, but it just seems off not pushing it into the flare stop on the axle itself. Maybe it's fine, but I don't trust it enough to roll with it.
OK, but did you have issues with the axel in the transmission? If not, then compare and install. Done.
If this is a manual transmission, maybe Kibbis was sent the wrong part and received the shorter axle for an Aisin auto.
shrevemini (08-27-2022)
Nice. One thing I noticed with the aftermarket axles is the size of the outer boot. They are a little larger and found out the boot will touch the bolt right above where the axle boot lives (passenger side). It didn't take long for the DTA axle boot to get damaged and spray grease everywhere. What a mess! Sucked it up and bought a GKN axle and all is good.
R50/53 Driver side axle gap
wojtek@pagacz.ca
08-27-2018 12:16 PM
srponies
12-06-2013 01:09 PM
GreekDrifter91
04-02-2013 05:13 PM
