MCS Paddle Shifters??
Okay, before you dismiss my outrageous question, let me explain. I recently had a gap in my growth plate in my hip. To solve the problem, a screw was surgically inserted to pull the gap together and prohibit my hip from slipping out. Too bad that didn't take, because the screw broke (as you can tell, that doesn't happen very often). So, a second surgery attempted to repair the broken screw and the hip. The old screw is still in there, and I have two new screws holding the hip. Trouble is, the new screws are hurting and I am not allowed to drive my MCS due to the clutch because it may cause another break!![Mad](https://www.northamericanmotoring.com/forums/images/smilies/mad.gif)
Worse case scenario: I have a chronic hip condition that inhibits me from driving my 2002 MCS. Are paddle shifters even close to being an option? Is there any possible way that I could still manually shift, if need be, with out using my leg? Automatic is outta the question, I would rather buy a Twin Cam. Thank you for your help and expertise.
As an option for 2005, you will be able to order the automatic transmission that comes with paddle shifters. I know you said you wouldn't go for an automatic, but so far all i've heard is good reviews about it. I heard the the tranny is very sporty. The shifters is the best part about it, that might help make that decision.
Danny
Danny
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
Danny![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
Danny
I picked up a brochure from the dealer last time I was there and it was all about the new LSD and tranny for 2005, there was a pretty good write up with pictures of the steering wheel with paddles but what caught my eye was the wheel shown was the standard two blade style and not the newer three blade with the play station like buttons. The paddle buttons where just below the thumbs rests on the sport style wheel and seemed to be more of a thumb button then a paddle on the back side of the wheel. Maybe the paddle cars will come with the more popular two blade sport wheels.
![LOL](https://www.northamericanmotoring.com/forums/images/smilies/lol.gif)
I played around with "clutchless" shifting in my old Honda... what worked best for me was to give just a little gas (don't know how well this will work with the drive-by-wire MINI) and pull on the the stick. It would pop out of gear and then I would feather the gas pedal as I tried to slowly pull the stick into the next gear. Once the RPMs matched it would slide in with just a little grind (or sometimes a lot
I quite often do clutchless shifting in the MINI and its actually quite smooth. Yes, you obviously have to match up the RPMs, thats what its all about. Well, that and knowing how much gas to give it to pop the engine from 2500 to 4700rpm. With practice, it makes driving so much more fun because there's even MORE to concentrate on. But yea, when the rmp's match, the shifter just sliiiiides right in. SO gratifying!
Hey sketchedin, sorry about your hip problems...well in order to break good news, YOU can get a MCS with auto trans and paddle shifting. Even with the CVT, the sport shifting is awesome too! Its shipping to Hawaii April this year, dont know about where you live, but it would probably be sooner.
Hopefully you can get the MCS auto. Its still just as fun!!!
Keep up the health,
Matt
Keep up the health,
Matt
Isn't there some method to move the clutch to hand controls like they would do for the gas and brake for handicapped folks who can't use their legs. I would think that there are companies out there that do this kind of work. You might look into asking some hospitals or rehabilitation centers in your area about places that do this kind of work.
There was some sort of switch in the **** that sensed pressure and would operate - a solenoid, maybe? Maybe there's some sort of aftermarket thing like this that can be installed, and I think MandaBoo's suggestion of tracking down shops that modify cars for the handicapped is probably a good place to start.
As a side note: resting your hand on the shift **** is a no-no in most cars. That little bit of weight travels down the linkage and puts pressure on the shifting arms inside the gear box. My wife's Healey mechanic showed us a transmission with surprisingly bad wear on this part, and that was the cause. (This probably isn't a problem with our MINIs' cable operated shifters, but I try to keep my hand off the **** just in case.)
A-n-y-w-a-y - one of the guys in my dorm in college had one of these VWs, and boy, was that a great way of teaching you to keep your hand off the freakin' ****! Had a few very embarrassing moments in that car!
http://www.accessunlimited.com/drive...rivematic.html
Drivematic: Automatic Clutch System for Manual Transmission Cars
The Drivematic system can be installed in any domestic or foreign vehicle and can be easily transferred from one vehicle to another, incurring only labor and minor hardware costs.
Good luck!
bee1000n A little Google search, and the answers come pouring in! I didn't look too carefully, but this might be of interest:
That was a very clever idea and was kind of you to do the research.
As I read through this Driveauto clutch system, All was excellant untill I read this. Might be a problem for the small size MINI.
: ALTHOUGH THERE ARE SOME VEHICLES WHICH PRESENT SEVERE SPACE LIMITATIONS OR AN EXTREMELY HARD TO OPERATE CLUTCH*, VIRTUALLY ALL MANUAL TRANSMISSION VEHICLES, FROM TRACTOR TRAILERS AND VARIOUS TYPES OF HEAVY EQUIPMENT TO SEDANS AND PICKUPS, CAN BE OUTFITTED.
First, let me say that I am sorry about your condition. Secondly, I just have to say that you may have a screw loose in places other than your hip if you are even considering somehow converting your present car. The notion that you could cheaply convert a stick shift car to paddle shifters has to come from someone with little experience with automotive systems. You can't make a silk purse out of a sow's ear, and you can't make an automatic tranmission out of a manual. By the time you add the actuating solenoids and electrical system to your car, it would probably cost more than a new one. Cost-wise, trading in your car on a 2005 with auto and paddle shifters is the INEXPENSIVE way to do this. Anything else would be a mechanical nightmare at huge cost, if it is even possible.
wildwestrider
12-27-2015 08:20 PM
embiggenedmini
10-15-2015 12:36 PM
molala
10-02-2015 01:53 PM
