Head valve replacement questions
07 mini base hatch non S
TIming was done by PO resulted in bent valves, and a broken valvetronic spring. Head is off currently.
1) process for removing valvetronic assembly/valve springs? The springs on IN side are tucked in the head pretty well. And I see there's a special tool need for the valve tronic spring? Any guidance on that would be great.
2) I know on 1st gen minis the non S engine can have the S head swapped on. What about for the second gen? Seems it's easier to find a S head where I'm at.
Can't help with the swapping cylinder heads.
Just a word of caution regarding valve springs. No Brand was spot on regarding the danger a valve spring presents to the eyes if it comes flying out.
But you want to handle the valve springs with extreme care removing them and installing them.Any damage to the valve spring wire can result in a stress fracture of the valve. This ain't good.
So it is best to use the right tool to help remove the spring. To keep the spring from popping out from under an rusty screwdriver and to keep from in any way damaging the spring's wire. And if you have more than one spring out keep them from banging against one. Don't just toss them into an old shoe box.
R50/53 Broken Valve Spring
wojtek@pagacz.ca
14
05-23-2018 02:32 PM
Steven_RW
08-02-2016 01:42 PM
Drivetrain Modified head: Cautionary tale!
Spyke in Dallas
12-03-2007 07:35 AM
