Dorman OE fix power steering pump?
Looks like I need a new power steering pump.
Has anyone tried the Dorman's power steering pump OE fix claim?...
https://www.rockauto.com/genImages/4...Case-Study.PDF
Thanks!
Thanks!
Don’t have any info on the Dorman but have you checked your VIN on the MINI website to see if your car is part of the power steering pump recall?
https://www.miniusa.com/owners/tools...rt/recall.html
Before buying a new one, did you consider trying to fix it yourself? Depending on how it's damaged, you might save yourself the hefty cost of a new one.
I didn't try myself, but found this video to be informative. They seem to be prone to dirt accumulation, and even just cleaning it without going further could be enough to bring it back to life (the video shows much more, but dirt accumulation was the actual issue).
Minibeagle (02-20-2023)
https://www.youtube.com/watch?v=kPadyoQz2rs
I am considering a rebuild, but am exploring my options too.
The machined pump face on mine looks like it's been leaking for a while.
I haven't been able to remove the contamination.
Not sure how good of a seal I'll be able to get...?
on
Bosch rebuilt is $500 U.S. (+$220 core) at Rock Auto in case the Coca Cola treatment doesn't fix it
https://www.rockauto.com/en/catalog/...ring+pump,7380
Bosch $375 "new" on Ebilbay
https://www.ebay.com/itm/16592301969...3ABFBMvqy5vMdh
$663 FCPEuro gets you lifetime warranty
https://www.fcpeuro.com/products/min...78425#warranty
Dorman has been back ordered for a while, so i would double check those places. Bosch we can get, some others are out of stock.
AAE ones are back in, they were the go to before all the others entered the market and rebuilding.
https://www.ecstuning.com/Search/Sit...h/32416778425/
ZF and bosch were OEM.
I didn't see it in stock, just saw it as an option.
Good to know it may be hard to find.
*IF* the rebuild doesn't go well, did you know or hear of how these "OE fix" Dorman's performed?
Welcome,
They are fine, i have not heard or seen any problems with them, its just availability. AAE has some in stock and we can get them, they are one of the few we can get right now.
I just dont want you to have to wait.
on
Reviews of the Dorman so far are "meh" at best
Cheapest price found, $288 at Jegs (on 'back order').
https://www.jegs.com/i/Dorman-Produc...9-950/10002/-1
Maybe they pulled it from the market due to quality issues / component availability etc
Yep, looks like a bunch had shipping damaged plugs, I have seen the Genuine MINI one do that. Pump is heavy and flips in the box, seems like a weak spot.
Just go with the AAE part and get it fixed.
Also i would do the lines at the same time and make sure you get al the old oil out. The reservoir has a built in filter.
https://www.northamericanmotoring.co...ng-hose-431263
https://www.northamericanmotoring.co...placement.html
A shop told me that my feed hose and my pump are leaking. I've looked around the web - youtube videos, here, etc. - and I see a lot of stuff about fixing the electrical probs, but nothing about leaks. Do PS pumps leak? Is that a common problem? Or are these guys just trying to turn a leaky hose replacement into a big $$ money maker?
PS pumps can leak, but most of the time its the lines leaking down on it. Clean the lines and at the connection point, if the pump leaks it will be at the neck or the plastic side of the pump.
Caterpillaraoz
04-11-2018 02:27 AM
