R60s misfire
R60s misfire
Hello everyone,
Hoping someone has an idea where to start with this. So I was getting low boost codes recently and decided To change my turbo on my countryman from the standard s turbo on the n18 to the JCW turbo. I finished the job yesterday and took it for a test drive, It was driving great and built 10psi but after about 10 minutes I got the same low boost (2C57) and wastegate (2CB3) codes. Today I decided to try adjusting the wastegate and took it for a test drive. It drove great again but after 10 minutes I got a huge misfire on cyl 4 and 3. Limped home then Tried swapping the plugs and coils around and the misfire Is persistently on cyl 4 & 3. Set wastegate back and problems persist. (Codes are 2EFE,2F02,2EE0,2EED,2FAB,2F01,2EE2,2EEC,2EF0)
maybe it’s a sensor?
Im stumped here, any help is greatly appreciated!
Solved
Actually figured it out yesterday so your timing is immaculate. It was a bad DME unit. Found a numbers matching unit from a Countryman being parted out and had the data from my DME cloned onto it. Runs a million times better and fired right up first try. The way I traced it back to the DME was checking continuity while the engine was running on each of the coil wires. I had no continuity on cyl 4 which was the source of the misfire. The guy I had clone my DME said that a faulty unit will usually present its self in the coils or injectors being shut off and that causing the misfire.
https://aetoronto.ca/ is who cloned my unit for me. Highly recommend Tony to anyone in the GTA who needs a cloning or diagnostic work. Super knowledgeable guy.
Ever find out what it was? Injector(s)? Run any cleaner through it?
https://www.northamericanmotoring.co...injectors.html
The misfire was strongest on cyl 4 with the occasional misfire on cyl 1 and 3. Numbers matching meaning the bmw & Bosch numbers. My bmw # was 7648190 for example. It’s a little tricky to find a used unit but it’s a couple hundred vs a couple thousand buying a new unit.
Where is this number? Is it a series number on the unit? Like a rev/version number?
it’s on the backplate of the dme, they typically start with a 7 or 8 for this generation. The Bosch unit numbers are printed a little smaller above towards the top of the labeling
FrankMstein (04-25-2023)
R60 2012 R60 misfire
Headacher60devin
08-30-2022 06:01 PM
ellieoux8
03-29-2022 04:24 PM
daonlyillwiz
07-09-2016 10:48 AM
