Rough idle after cold start
Old 09-19-2024 | 05:58 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Originally Posted by P.Maho0788
Observed issues only under load (medium torque): misfirings and very little throttle respsone --> like little crackling when pushing the paddle
In idle I could not observe any misfires, even when reving up to 3-4k.
Compare the fuel trims with the engine idling (no misfiring) versus the engine under load (misfiring and poor throttle response).
Also, is fuel still leaking into the crankcase and what is the fuel rail pressure when engine is idling versus when revved?
  #27
Old 10-10-2024 | 02:08 AM
P.Maho0788's Avatar
P.Maho0788
Hey there - currently on vacation but before I brought the car to a mechanic. He has some new findings:
  • he verified my prior obsevations (compression ok, no air leaks and so on)
  • did a leakdown test : -20% on all cylinders!
  • major pressure out of the oil fill cap (it bursted a rubber glove) while engine is running
Could it be that the timing is off? Or are there other possibilities left I could check first?
cheers
  #28
Old 10-10-2024 | 04:37 AM
Maybe, maybe not
Confusing
Good cylinder compression combined with a bad leakdown test doesn't make a whole lot of sense.
If the mechanical timing were off and the pistons were not at TDC during the leakdown test, air should leak from the intake or exhaust not the oil fill cap.
  #29
Old 10-10-2024 | 12:49 PM
P.Maho0788's Avatar
P.Maho0788
Agreed - This makes also no sense to me…*sigh
Anyways, will bring it to another mechanic who has more experience with R56‘s N18 and hope for the best. If he also has no success I will rip the engine apart and see if I can find anything suspicious while replacing the piston's with forged ones and all other internals (which I have planned anyway).
Could it be that I have a faulty ECU - since it throws no codes? If so is there any method to check other than reflashing?
I really don’t want to throw my mini to the scrapyard…:(
Barry_r57
R57 :: Cabrio Talk (2009+)
03-18-2024 02:32 AM
sleepingbrain
12-20-2023 08:12 PM
HoosierCooper
09-03-2021 11:34 PM
jamesfacts
10-01-2020 06:14 AM
Mini'mon
08-01-2008 07:37 AM
Quick Reply: Rough idle after cold start
