Rough idle after cold start
Hello everyone, greetings from a long time lurker. I am hoping that anyone also had my/similar issues or can lead me in the right direction to solve my issue with my R56 N18 Cooper S (180k km). I have INPA & ISTA available.
After having a failed spark plug and coil, I had to drive back home on 3/4 cylinders - replaced all plugs and one coil and then the misery began.
Startup is good but as soon as the coldstart is done the engine runs (on all cylinders) in very rough idle with RPM going up and down in between 600-900RMP until eventually dying. Since no codes are shown (read out with Ista and Inpa) I already checked nearly everything and replaced many(see list below) old/faulty/worn parts - no success.
List of doom:
Any tips/ideas are welcome - since I have none left [img]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img].
Cheers!
English is not my mother tongue
List of doom:
- Cylinder compressions - ok
- Cylinders inside (endoskop) - ok
- Vanos cleaned (both)
- chain tensioner - replaced
- valve cover - replaced
- intake manifold gaskets - replaced
- inlet/outlet valves - ok , no carbon
- throttle body - replaced
- fuel breather valve - replaced
- All air intake sensors - replaced
- O2 sensor (pre cat) - replaced
- Sensor cooling water - ok
- ambient temperature sensor - ok
- Railpressure - ok
- Reset all adaptations after I replaced all the parts
Cheers!
Hi Maybe - thanks for the reply!
Are there any "hidden" vacuum lines I may have missed to check?
Greetings
- no air intake leak could be found (tested with smoke and starter spray)
- vacuum leaks could also not be found (so far)
- LTFT: +0,1%
- STFT: -25%!
- AFR: 13,52!
Greetings
MAF shows 20kg/h at idle and increase with throttle accordingly. Also checked the airfilter - all good.
Good point regarding the injectors - will check tomorrow asap.
I have 2 questions: Would it be „enough“ to run them with carb cleaner while open/close them with an external 9V batterie to check for leaks?
Do I need special tools to either replace them or fit back the old ones after cleaning?
Thanks for the help!
P.Maho0788 (09-10-2024)
Hi - thanks for the video! Since I could check nearly all the points he mentioned I checked my injector's and oh boi what a mess :D.
Two of them have been leaking so I replacement them all to not have to check them in the near future (hopefully).
I did a reset of all adapdations and after a few misfires they engine runs way better and does not stall anymore but the problem is not 100% gone. (jumping RMP still a bit and stft -19%)
Do you think that this might be due to the ECU needs time to adjust to the changed parts (and adapt accodindgly) since I didn't had the time (yet) to go for a proper testdrive.
Cheers
Cheers
Maybe, maybe not (09-10-2024)
Thanks! I'm already excided if that's finally it - did only run the engine in idle for like 30sec to check if the fuel-rail is good and if it's holding the pressure after turning off the engine as stated in the video you linked - all perfect!
Before my testdrive however I really need to do an oil change first...just checked it and (prob. due to the leaking injectors) it's over max and smells very stong petrol'ish.
Wish me luck! - I will update this thread as soon as I come back tomorrow.
Quick update: Wanted to drive to the place where I do my oilchange (~2km) but I had to return after the first 500m due to lack of throttle and misfires.
Observed issues only under load (medium torque): misfirings and very little throttle respsone --> like little crackling when pushing the paddle
In idle I could not observe any misfires, even when reving up to 3-4k.
Do you have ideas what could cause this or any tests I could run do to give more insight?
My next plan is to check for the cylinder 1-4 misfire counters via OBD and to hopefully find a faulty coil.
Nope - maybe I didn't had only 1 but 2 damaged coils? Since air is fine and fuel also - the last thing would be the coils (since I only changed 1 because it was running on only 3 cylinders).
Or something totaly different - could it be due to a low battery? Mine shows the low power warning at start up, but the startup itself is instant and without any hesitation.
You may want to check whether the serpentine belt is turning the alternator pulley and whether the alternator is able to charge the battery.
What voltage do you read across the two battery posts when engine is off versus when engine is idling?
Will check the operational smoothness values and misfire rates for the 4 cylinders in idle and while driving when I come back later.
The battery is kinda low due to short engine run time within the last 6 weeks and OBD diagnostics with engine off but CL15 ON. When I let it idle and/or go for a 1-2min drive the warning stays off for a couple days. I think the battery might need a proper drive to get charged to full.
Hi there - since the missfire counters and smoothness values did not show any suspicious data, I did multiple short (1-2min) drives to check the spark plugs after every run and tested with 2 sets of new ones.
The sparkplug of Cyl. 1 always was full of carbon and the other 3 looked pristine. I also switched the plugs around and the ones looking good turned black as soon as I put them in Cylinder 1.
So my conclusion is that I really do have another bad coil. And if its not the coil then it must be the wiring/connector - although I could not find any damage/issue when I checked them.
sleepingbrain
12-20-2023 08:12 PM
jamesfacts
10-01-2020 06:14 AM
Drivetrain Help! Installed BPV and now car won't start!
Mini'mon
08-01-2008 07:37 AM
