R52 2008 Convertible Top not opening.
Old 10-05-2024 | 06:17 AM
Cachuttm's Avatar
Cachuttm
Hello guys!
I’ve been reading a lot of threads, but just a few I’ve found that describe the behavior in my r52, but still no ideas on a solution.
My top will open the first stage, but then won’t do anything else. It won’t lower the windows, it won’t show a blinking red light either. Yes, I checked the rear shelf, and even replaced it just in case. I also replaced the module but still not operation for opening. And I say just for opening, because I have opened the top manually, and it will close perfectly fine.
Recently, I bought a scanner that would read the CVM module, and it’s coming up with some codes.
It says, “Switch, stowage lock, right: short circuit to ground” and also “Switch, stowage lock, left: short circuit to ground”.
I’ve read that after 2005 the r52 have this extra system to lock the top when stowed. I tried replacing the green relay, but nothing changed.
According to the scanner, the hall sensors are reading what they are supposed to.
what seems weird to me is that both switches have short circuit, And frankly I’m not sure if the piece for that switch is this triangular shape piece that I know is in both sides of the car.
If anyone can please give me some hints or clarification on how to fix that code, it would be greatly appreciated.
Old 10-05-2024 | 06:58 AM
Here2Go's Avatar
Here2Go
NAM Community Team
Have you posted the question in the R52 Cabrio Talk section of the forums?
You may be able to receive better results to your query.
Old 10-05-2024 | 07:33 AM
Cachuttm's Avatar
Cachuttm
No, just in this one. I wasn’t sure if that would be a right place to start the post
DiscoDave
01-31-2023 07:15 AM
Zachary Pollard
R57 :: Cabrio Talk (2009+)
03-21-2021 08:16 PM
wcbrewster@mac.com
08-02-2018 07:29 AM
RudeJoe
04-09-2018 06:16 PM
slide mini
12
01-05-2015 02:44 PM
Quick Reply: R52 2008 Convertible Top not opening.
