Cold Range Spark Plugs?
Time for new spark plugs?
In a couple weeks I am going to be begin the mods by installing a 15% pulley, bora cat back, cold air intake and the computer reprograming. Should I put in (correct me if i'm wrong) cold range spark plugs? I thought i saw somewhere that if you were to install a reduction pulley it was a good idea. any thoughts?
I will soon be adding a 15%pulley, Borla Cat, Cold air intake and I thought i read somewhere that it would be good since I am added the 15% that I get cold range spark plugs, does that make sense. please correct me if I am wrong but thats what i thought i remember them being called, thanks!
I ran my pullied MCS with stock plugs for several months then switched to IK-22s and both work fine. No real difference I could detect.
Your thread was moved over to Beneath the Bonnet.
webb
I ran a month with stock on the 15%, but put in IK22 more so cuz it was recommended by randy, cobra websites, M3 webistes, etc. Did I notice a difference in whp or torque? hard to say haven't dyno'd with them. I put them in with the screamin demon coil and live wires from Mossmini. I did notice it fires up at the hint of turning the key.
Originally Posted by Veni_Vidi_Vici
I thought that the cooler plugs stopped detonation, which causes retardation of the spark causing loss of power. So while they don't add power they prevent power loss.
Or I could be F.O.S.
Your almost correct
Colder plugs won't stop detonation but will help prevent it. Since timing is controlled by the ecu, unless you have a bunch of carbon build-up that would increase compression, plugs are the most common cause of detonation. You'll not hear any pinging, the ecu will retard timing by, I believe, as much as 11 degrees. That equals a big loss of power. With all the money I spent on pulley, intake and exhaust to make more power, damned if I'm going to lose that power to save a few bucks on plugs. My .05(inflation
![LOL](https://www.northamericanmotoring.com/forums/images/smilies/lol.gif)
I ordered the Beru plugs from Outmotoring.com. They were $28 plus shipping. I know it's not as common a plug as the Denso IK22, but reviews I found seemed to indicate they are a good plug.
on
Originally Posted by aokdoug
got mine @ ltbmotorsport.com $9.95 ea.+ shipping.
best price on web i could find. beats others by a bunch.
also use 1-888-346-7266 if link doesn't work.hope this
helps.
doug
helps.
doug
![EEK!](https://www.northamericanmotoring.com/forums/images/smilies/eek.gif)
bigserb3
08-31-2015 09:54 AM
