oil pan screw stripped
anyone out there had a problem with their oil pan screw? i was at steve's yesterday for an oil change and the threads for the oil pan screw came out with the screw....
called my warranty company as my miniusa warranty expired 4 thousand miles ago and they told me that it is caused by human error and is not convered... either by over tightening the screw or putting it in off kilter.
steve said it is metal fatique due to the fact that the entire thread came out.
just wondered if anyone has experienced this?
on
do you mean to say that the threads in oil pan hole are shot? it should just be the bolt threads. if so, just a new bolt would do.
typically, bolts are made of a softer grade so they get screwed-up, not the threaded portion that is more difficult and/or expensive to replace. as an example, i x-threaded one of my rear control arm bolts, and it was just the bolt which was less buck or so...
By saying that 'the threads came out', did you end up with crumbling aluminum fragments on and around the bolt threads, or did something resembling a steel spring come out with the screw? If it is the latter, than at some point the threads received a helicoil thread insert from being stripped out (I doubt there is one instaled from the factory) and this piece can be replaced quite easily. If it's the former, well, looks like you will need the latter done or a larger drain plug fitted.
oil drain plug
i appreciate the interest everyone, thanks
its really helpful in trying to make the right decision in how to proceed.
Get a ...
Originally Posted by manoo
i am still deciding. for the moment the screw is wrapped in teflon and i'm not driving much
steve and i talked about tapping it and using a bigger screw rather than replacing the oil pan at $230...
Do not tap it !!!
Just a suggestion... that is all.:smile:
(Doh, should have read the thread first... Greatbear already suggested this.)
heliacoil
thanks for the advice and thanks to great bear too. sometimes i have to hear things more than once to get the picture
so having said that, WHAT IS A HELIACOIL THREAD REPAIR KIT????
and where does one get one??
sounds like a better solution to me too. i really did not like the tapping idea. in fact i was going to bite the mini bullet and buy a new oil pan ($230)
to avoid future problems...but would much prefer using a kit providing that it does the job permanently and this won't be a reoccuring anxiety.
"Helicoil" is a product name for a thread repair sytem: you drill out the funky old threads for the special tap size required, then tap the new hole and insert a special thread insert whose exterior matches the new thread and interior the old. the "kit " usually includes the drill bit, Helicoil tap and a few inserts. you need a special kit for each thread size and insert lengths appropriate for the situation.
looks more like a spring made of aluminum... came out wrapped around the oil drain plug
Its not uncommon for that to happen with an aluminum pan, as it is soft metal. I would personaly say just to get a self tapping oil drain plug. You can get them at most auto parts stores. You can use a heli coil but if was you get a bigger drain plug, and just tap it out. Either way i would highly recomend dropping the pan. there is a small screen on the oil pick up but it still can pull up metal fragments and risk damage to the oil pump.
Just my two cents
See you at the dragon!!
Mike
Just my two cents
Mike
If you plan on keeping...
But a H-coil is better than drilling, tapping, and placing a larger bolt there.
Best of luck and success whatever you decide to do...:smile:
Originally Posted by ScottinBend
It appears that the pan was repaired once already. I would go back and talk to the folks that did the previous oil changes and demand that they come clean with why they repaired the drain plug and then have them replace the pan.
I tried cajoling, threatening, BBB, and only ended up
No way a shop will take responsibility.
Did get a used one to replace it for $30 though...
No need to replace the pan. Just take it off and take it to a good machine shop. Either a helicoil or a drill-out and re-tap for a bigger bolt will work fine (if done correctly). A self-tapping bolt will be OK for the short term, but if you want to be old-school and do it right, do a remove and repair number on the oil pan.
Doesn't surprise me
When the dealership did my last scheduled service they wrenched the plug on there a lot tighter than spec (judging by the effort to remove it.)
I won't be back - even if it's free it's not worth going through that.
To be honest I was expecting to see stories like this earlier than this. I'm sorry that it had to happen to you.
--Jeff
--Jeff
no kiddding
the weird thing is that i have been so careful about the dealers touching my car.... only the required oil changes.
thanks for the kind words.
i'm off to steve's to tap the hole and replace the oil pan plug with a larger one. steve actually thinks that it is metal fatique and not abuse due to the fact that the aluminum threads that came out with the plug are not damaged or bent in any way, sheared off in one piece.
try proving that to bmw
it is more than i can or want to deal with.
....it is metal fatique and not abuse due to the fact that the aluminum threads that came out with the plug are not damaged or bent in any way, sheared off in one piece.
When all is said and done to your satisfaction, I suggest that you do what I've done.
http://www.fumotovalve.com/
res ipsa loquitor (the thing speaks for itself).
MGC
MGC
