Check Engine Light question
My '03 Cooper has the check engine light on. We ran an OBDII test to get the fault codes and got the following codes with thier accompanying definitions from the Bently Service manual:
P0445 - Evaporate Emission System Purge Control Valve Circuit Shorted
P0031 - HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0037 - HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0340 - Camshaft Position Sensor 'A' Circuit (Bank 1 or single sensor)
Can anyone tell me what these mean? Thanks in advance.
Check the round connector that is near your driver's side headlamp. Several important connections, including the O2 sensors go through there. With the engine off, undo that connector, clean the terminals, reconnect. Clear faults and see if they come back. Also, check the connectors on the ECU itself. Check for fraying or insulation missing on any of the cables.
on
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
