Got 240 miles on 05' MSC, and I get about 17.5mpg. Is that too low?
Old 05-01-2005, 07:21 PM
LeftyS7's Avatar
LeftyS7
LeftyS7 is offline
At 4500' elevation, with a new MCS, I've filled up 5 times. I drive about 30 miles a day, mixed town and highway, with no stop and go traffic.The first time I got 19 miles per gallon, I decided to drive conservatively and try to stay below 3000 RPM and I got 21 miles per gallon for the next three tanks. The last tank I decided to have fun and got 19 miles per gallon. So 10% gas savings by driving conservatively. Not worth it. Let'er REV!
  #52
Old 05-02-2005, 06:26 AM
Inimay's Avatar
Inimay
Inimay is offline
I am getting improved mileage but still short of the advertised 27 and 32. By utlizing the computer and driving at minimal throttle and shifting early (aka no fun) have have gotten around 24 mpg in city. This past weekend did some long highway runs, DC to Philly and was getting upper 20's but due to some traffic. I think with clear running I may have been able to top 30.
Cruise control seemed to be the best way to get high mileage. Otherwise, my right foot would get too heavy and scew up the numbers :D
Overall, I think the mileage is getting better as the car is breaking in. Just went over 2700 miles. I don't know what person was able to get 27 and 32 on a consistent basis with a Cooper S.
Not that I bought this car for the fuel economy but it is close to the fuel economy of my thirsty VR6, which seems odd for a supercharged 4 banger. Oh well, I know I do save gas by being able to take turns faster... less acceleration.
  #53
Old 05-02-2005, 06:46 AM
kaelaria's Avatar
kaelaria
kaelaria is offline
If I use cruise and baby it around towm I get better than posted milage. However I choose to drive very hard, and am getting about 23 city right now, and it is still rising - I'm very happy with that!
If you are that low I would suspect you are using less than 91 octane or have blended fuel.
  #54
Old 05-02-2005, 07:18 AM
ditc's Avatar
ditc
ditc is offline
I'm curious guys: when does your "low fuel" light come on? I have had it come after 10.2gallons used and I have had it NOT come on even after 11.0gallons used , same weekly commute. At this point, I am suspecting some dodgy gas stations in the area maybe incorrectly inflating those numbers on the pump, and that is skewing my manual mpg calculations, and of course robbing more of my money!
  #55
Old 05-02-2005, 09:08 AM
inimmini's Avatar
inimmini
inimmini is offline
I have about 4000 mi on my '05 MCS, and mostly I've gotten 24-26 mpg driving around country roads (actual, not computer). Haven't seen much change since new. Recently, I just finished the first tank after the 15% pulley went on, and mpg was 27. Too soon to tell if this establishes a trend of slightly better mpg with the pulley.
  #56
Old 09-02-2005, 09:33 AM
Col.Bobby's Avatar
Col.Bobby
Col.Bobby is offline
Sudden mileage drop
My new MCS had been getting an average of 25mpg for the first 2,500 miles. It recently developed a "cold start" problem, which the dealer says is epidemid among Minis and BMWs recently (she blamed the quality of the gas, I use Shell premium). Then I had the dealer install the JCW air intake... Just filled up this morning and found that the mileage is now 17mpg. I can't believe this is within the "normal" range. What explains the sudden drop? Any ideas? If this continues for one more tankful I will ask the dealer to look into it. :impatient
  #57
Old 09-02-2005, 09:37 AM
BMDoubleU's Avatar
BMDoubleU
BMDoubleU is offline
did your JCW air intake come with larger injectors? if so, that might be part of the reason.
  #58
Old 09-02-2005, 10:22 AM
kaelaria's Avatar
kaelaria
kaelaria is offline
  #59
Old 09-02-2005, 11:38 AM
Wagnbat's Avatar
Wagnbat
Wagnbat is offline
4500 miles on the Batmini, and an average of about 27mpg suburban to urban city motoring.
  #60
Old 09-02-2005, 06:01 PM
Frank in Toledo's Avatar
Frank in Toledo
Frank in Toledo is offline
Originally Posted by tifosi360
I just filled up my 05' MCS for the first time (only got about 240 miles so far), and I've been getting 17.5 mpg. It seems low. Is it because the engine breaking in? I hope it improves!
Thanks.
My 14 month old "s" has a 27 mpg OA average. I left computer #1 go without resetting since the car was new. I would expect your mpg's to go up.
  #61
Old 09-03-2005, 08:18 AM
classpro's Avatar
classpro
classpro is offline
I have an MCSC. First tank said 29.5 mpg, which seemed really good. Second tank was about 26mpg. I am driving highway and country roads, no stop-n-go city driving. However, I am constantly verying the speed and gears for breakin. On the freeway, if the speed limit is 65, I go up to 65, take my foot off the gas and go down to 60, then gas to 65, etc. Also, I shift between 5th and 6th quite often, and drive in the lower gear. So I'm not driving in a way to maximize mileage. I have also taken it up to 5000+ rpm a few times to help with ring seating. It has burned NO oil so far (about 900 miles).
I LOVE all of the gears on the car, except first. First gear is a bit pickey - I've died a couple of times from a complete stop (once when my wife was yelling at me because I was putting the top down in traffic, the light turned green, and the top had not finished going back). Maybe I'm just not used to it yet.
  #62
Old 09-03-2005, 06:10 PM
lcubed's Avatar
lcubed
lcubed is offline
just did all the mpg calcs for my first 1750 miles.
overall mpg ~ 26 and best tank (this last one) was 30.03.
the previous tank was 25.4 and on the last one,
i took care not to push excessively quickly on the loud pedal
and yielded nearly a 5 mpg increase!!
  #63
Old 09-03-2005, 06:19 PM
Battle Cattle's Avatar
Battle Cattle
Battle Cattle is offline
i run 19-21mpg in my 05MCS (stop and go trafficall the time) and I run in 4th gear at top speed (70+).... also when I went to the dragstrip my computer said I was running 20MPG...
-Josh
  #64
Old 09-03-2005, 07:12 PM
Pendergast's Avatar
Pendergast
Pendergast is offline
Just got back from a 1500 mile trip. Averaged (by calculation) 29.84 mpg. A lot of it was cruising at 75. Overall mileage since purchase (via computer) 26.9 mpg.
07-16-2020 12:54 PM
phrza81
10-10-2015 11:37 PM
WestfaliaR
08-19-2015 08:01 AM
Bennyboy
08-18-2015 07:28 AM
08-12-2015 01:24 PM
Quick Reply: Got 240 miles on 05' MSC, and I get about 17.5mpg. Is that too low?
