Need airbag diagnostic tool
Airbag Diagnostic Tool - Easy To Use
use the following easy to follow diagnostic routine to determine the problem with your MINI airbag(s).
1) If the airbag is hanging out of the steering wheel, seat, dashboard or headliner, your airbag has been deployed
2) If the airbag is wet, your windows or sunroof is probably open and it is raining
3) If the airbag is frozen, your automatic airconditioning is set too low
4) If the airbag light is on, you probably moved the driver or passenger seat and loosened the connection underneath. There is a TSB related to this problem -- my '02 MCS had each seat airbag harness replaced, but they only did it one seat at a time as it failed. They also replaced the exploding seat belt latch/tensioner *twice* on the same visit, as the 1st replacement part was defective.
This is a well known problem, and they should fix it even after the warranty has expired, on a good will basis if nothing else.
Don't expect that one of these tools will fix this situation - the SRS system will still report that there's a problem if the entire airbag / belt tensioner system is not intact. It's there for a reason, although it's not very forthcoming about why it is illuminated.
Go to the dealer and get the problem fixed. In a car as small as the MINI, do you really want to take a chance that it's not going to go off in an accident?
Originally Posted by leon's rocket car
sorry jim, thanks I looked up my order and I got the other one. Got a guy down here that needs this one as well as he can't get the dealership to turn off his light after he changed his seats...
I'm pretty posistive it's the entire system. Don't bother calling the dealer. Refer to your warranty pamplet. For example On my Lexus IS300 There Bumper to Bumper is 4 Yr 50k. But all Emissions Items are 8 Years 80k When i my 02 sensor went bad they never told me about my 80k warranty until i look in my manual and saw this then they shut up and refunded my money. I'd offer to look but my cooper is En Route!!
-Joe
-Joe
Steffen.Johnson
42
01-25-2023 02:47 PM
wildwestrider
11
01-29-2016 05:06 PM
