Intercooler cover...needed?
Is there a need to keep the intercooler cover on a stock MCS? It seems that if you took it off you would be increasing the amout of surface area that would be directly in contact with the airflow from the scoop. Granted its would be a minute difference (im assuming), but Im not a huge fan of plastic covers on my engine parts. Any info, or thoughts would be appreciated!
-Jake
-Jake
I haven't looked at it closely with the idea of removal, but here are my thoughts:
It's not a cover, it's a duct. It provides the air with a tuned path through the intercooler. If the entry is smaller then the surface of the intercooler, it's likely done to increase the velocity of the air.
These little things are added to the car for a reason....even if the reason isn't immediately obvious to us. Sometimes the engineers screw up, but over all they know the system best.
The hood has a sealing strip that surrounds the intercooler and focuses the airflow from the scoop. This 'weatherstrip' seals against the plastic intercooler cover and makes the scoop more effective. If it were to seal simply against the edges of the intercooler itself, the engine movement will grind the edges into the weatherstrip and wear it out. Plus, the intercooler is not completely centered in and does not take up the whole area of the opening of the scoop. The cover helps to prevent air moving past the intercooler and become 'wasted'.
It also tidies up the engine bay somewhat. And it gives those with the JCW kit a spot to show off their stuff, as the JCW has a different color cover with logo.
Originally Posted by PARTSMAN109
Hey Greatbear,
Any input on the Alta Air Diverter?
IQRaceworks
53
06-28-2024 07:29 AM
gar56
11-15-2016 06:41 AM
