V41 Software and Cold start
#26
#28
Mine has Herky-jerky and cold start idle
05 MCS build date: 02/05
I too would like to know how to verify the Rev on the firmware. My experience with dealers has been such that I like to have some knowledge of the problem to keep them honest
Exhibiting the following symptoms:
Cold start idle stumble.
Herky-jerky on throttle let-off.
Throttle let-off lags at times. revs stay up (or should I say come down slowly between let-off of throttle and clutch/shift. Like the old SU carbs when the dashpots were messed up)
Here are a couple other things it does that may or may not be related:
Tailights have stayed on.
Cruise control only works on some days. Like this since day 1.(Today it worked but hasn't worked in over a week.)
The car does a number of things that are annoying at best. If it weren't for having owned other quirky british and italian cars and know that I'll probably just have to live with some of the idiosyncracies I'd probably not keep it. But it's just so much fun to drive when it runs right
#29
Originally Posted by Ramjet
How can you tell what version you have? and not to sound dumb, but what is the MTH?
you can search this forums for MTH and find a threat called MTH - member support.
or go to: www.mth-powerchip.de
#30
I feel your pain, Sndwave. When I took my car for the 2nd maintenance a few months ago, I specifically asked them not to update the emissions problem. They said they had too and ever since my car has the accelerator jerk like people describe.
I've given up on my cold start/hot start issue getting fixed. I don't live as far away as you but I'm not close enough to drop it off and come back either.
Just to clarify, I love my MINI and wouldn't trade it for anything......well.....maybe an 06 I would.
#32
Originally Posted by sndwave
When I had the v40 upgrade done because of the recall notice, not because I wanted it done, it took a couple weeks for it to start acting bad. This is not my imagination and seems to come and go, but it is because of the ECU update that was installed.
I do not live close to a dealer (600 mile trip). I can not just pop in and have every new update flashed when MINI/BMW wants to try a new program.
I know it’s not going to happen, but I want my v32 back.
I am campaigning to get v32 re-installed.
Just picked up mine after the install of v41. So far it hasn't made it worse, but it didn't fix anything that I can tell. The cold start was intermittant and not predictable. The car was doing the herky-jerky off-throttle thing within sight if the dealer. To the dealers benefit, they never said that they fixed that problem. They tried not to talk about it at all.
#33
#34
#35
Originally Posted by warchieft2k
I agree with kaelaria, my cold issue and my jerky issue were both fixed my my MTH flash.
#37
#38
Originally Posted by jblow
What is the recall; what build dates are affected?
I drove around with duct tape on my breather hose for 7 months because it had split apart and still had better performance with the v32 that I do now with the new hose and v40 installed.
#39
Originally Posted by CoryB
Hey Hobbit
Did the dealer reset the ECU after the upgrade? Or have you done so?
Based on your description of the problems within sight of the dealership it sounds like it didn't get done.
Heck, even if it did, do it again. It won't hurt anything.
Guess I'll do the 19-21 reset thing as you say, "It can't hurt".
I'm thinking of trying the VGS modification. I'll let you know.
#40
Installed the VGS modification on Sunday, 26-6-05, and the jerking problems are gone .......... at least for now. Drives like a different car. Throttle response is much better, no off-throttle problems, or at least very minor, so minor that they can be masked by poor roads.
I did have another cold start stall on Saturday, still intermittant, no pattern that I can find.
#41
[QUOTE=Bilbo-Baggins]Installed the VGS modification on Sunday, 26-6-05, and the jerking problems are gone .......... at least for now. Drives like a different car. Throttle response is much better, no off-throttle problems, or at least very minor, so minor that they can be masked by poor roads.QUOTE]
Okay, I too have the herky-jerkies, so I'll go ahead and risk exposing myself as the class dummy. What is the VGS mod? An ECU upgrade? Who makes? Where do you get?
Edit: I did a search and found it. Guess I should have done that before posting!
#43
Originally Posted by Hounddog
Ok so I'll re-ask the same question, how do you know which version you have?????
#44
[QUOTE=BrianGoldbloom]
LOL, maybe so.
It is as easy as it sounds, takes about an hour to do it the first time. I'm sure I could do it faster now.
The difference is now I know that it is easier to take more apart and open things up than to fight the cramped spaces. And, Oh yes, 11" pliers or 11" forceps make things much easier.
I didn't bother to adjust the butterfly of the By-Pass valve and it still feels great.
alistaircookie
10-08-2015 10:52 AM
minipopkart
08-13-2015 05:22 AM
