Rough Idle, the MINI take
While I was in getting the Alarm and rear fog activated I asked my SA about the rough idle that 05's were having. Apparently they are just calling it a characteristic of the vehicle and not going to release any more ECU upgrades to try and fix it, as the 'fixes' has given more problems than the rough idle. The rough idle is caused by when you come to a stop, in neutral, the ECU backs off the injectors and goes too far causing the problem. Just thought you guys would like to hear that.
I am not sure I would call it a problem. However, that said... since I flashed MTH the car runs and idles much smoother. I wouldn't have even been aware of it... until not having it. So a big deal? No, I don't think so... but it can be eliminated. My 2 cents - for what it's worth. BTW - mine's an 05 MCS JCW.
Same problem here. I upgraded my '04 WORKS to '05 specs and I got a nice rough idle as a freebie!
Usually happens when I come to a stop. My SA said it had something to do with programming and air purging? Didn't quite catch that one. He did say that there may be a corrective download in the works.
It's more of a nuisance than anything else but after what I paid for the upgrade kit you think there'd be a fix on the way.
Aloha!
JCW04
Aloha!
JCW04
The SA at Princeton MINI in New Jersey told me that mine was due to the aftermarket coil, wires and cold air untake.CAN YOU BELIEVE IT!!!! Mine in an '03 that DID NOT have this problem BEFORE they flashed it with the new update. My car has 21,000 miles....the mods were made two years ago when the car has 156 miles on it. Incompetance at its best!! Oh, and by the way, did NOTHING to fix it...Essentially TS for me!!
Its nice to know I am in good company on this one. I just got the emissions 'upgrade' as well.
More recently, and perhaps not due to the same upgrade, I find the motor no longer starts on the first turn of the key. Whether I give it gas or not, it wants to stall once before it catches. Its fine after that.
Originally Posted by bodinski
My 12-02 build '03 non-JCW MCS did it once in 20,000 miles. Then I got v.38 & now it happens frequently. I don't think that JCW has anything to do with it. It would appear to be in the recent code for all MCS's, JCW or otherwise.
