Rubbing Sound when turning at parking lot speeds
the right front of the car makes a rubbing sound, only when turning slowly (say in a parking lot or in and out of a parking space). at speed above 10-15 mph, it does not happen. the dealership told me it was my tires (as they were worn down), however after replacing them, the sound is still there. i searched the threads and didn't really see one that matched my description--anyone else have this issue?
I have the same problem after putting new tire/wheels.
there is no way the tire could rub anything as the car is on stock height and there's plenty of space everywhere.
let me know if you find out anything. I couldn't figure it out..
Maybe it's the power steering noise? but don't remember it being this bad.
When I took mine in, they said it's just tire noise
I have stock tires now and the sound is still there, although a bit less noticeable. Mine only sounds when I'm making a hard right turn with throttle.
I've decieded to just live with it. If something breaks, they should fix it as I still have a lot left on the warranty
yeah, i don't like the 'it's just tire noise' excuse, especially when it comes to suspension...i've never owned a car that made rubbing/screeching sounds when turning, but i have had tire noise with high performance summer tires, which was expected. i'd definitely push the issue. it the sound wasn't there when it was brand new, it shouldn't be there now.
I had the rubbing noise as well, busted front tie rodhere, fixed under warranty, but that did not produce the rubbing sound, my car guy said that there is a backer plate next to the rotors and they get rust on them which produces the rubbing sound, he put the car up on a lift and proceeded to turn the wheels and grind off the rust until the noise went away, it's back again but I think I should be able to do the job myself this time around,
tommyb
tommyb
For a year now
The noise I hear sounds like the noise you get from a very old shock absorber, almost a creaking noise. Is that what everyone is hearing? I've had the noise from day one and it's been a year now. Maybe something isn't lubed enough is my first thought. I thought for sure if there was something seriously wrong with it, it would have been obvious or worsen during MOTD. Nothing. Still the same, no worse. Things that make you go "hummm".
I get a steady "whoop-whoop-whoop" rubbing sound from the right front of the car when turning left at low speed. Not a creaking noise, a friction-y noise. It sounds like tire rub, but it's not tire rub -- I have plenty of clearance. While my runflats have 23k on them and are somewhat worn, I can't believe this is the fault of worn tires -- they'd have to be ovoid or asymmetrical to cause this noise.
I'm going in for my 25k check in a week or two, and checking the strut mounts and tie rods is high on the to-do list.
When you turn left, you load the right side...pretty classic for a wheel bearing problem, I think.
I had this same problem - occasional creaking sound on slow right turns - with my 06 MCSC, starting about 6 weeks ago. No major potholes or other suspension catastrophes, just regular driving. I do traverse about 6 speed bumps on an average daily commute, but I take them slowly and gingerly.
Anyway, had it fixed when I took her in for the 10k service. It was a cracked strut mount, replaced under warranty no questions asked. However, they implied that if the strut itself had also been damaged they would not have done a warranty repair.
Now I'm thinking maybe I should bug them to replace the other side with the newer/better strut mount before it too collapses and potentially causes more serious damage.
07-16-2020 12:54 PM
Gil-galad
Eastern Iowa MINIs
63
11-17-2016 02:54 PM
Powershift
08-16-2015 05:14 PM
