Stripped Bolt Head on Oil Drain Plug
Hi Everyone.
I've been changing the oil on my '05 MCS about every 6K to 7K mi. Roughly twice as often as BMW reccommends. The dealer did it the last time as part of the regular 10K service (done at ~13K be/c that's when the service indicator told me to..I do a lot of highway miles). Anyway, I've got 20K on the car and it's time to change the oil again except the gorillas at the dealer torqued the drain bolt so tight at the free service that I couldn't break it. Long story short, I stripped the corners on the hex bolt. Don't ask me how. I was aggravated and in a rush, not a good combination.
Can anyone offer advice on how to unscrew the stripped bolt? I am ordering another bolt and washer. Can anyone foresee any problems as a result of this like thread damage when trying to unscrew the old bolt?
Any help would be greatly appreciated. Thanks.
~Paul
~Paul
The easiest way to loosen a bolt with a stripped head is to use a Visegrip and gentle hammer taps on the head of the bolt. It will probably be best to do it with the engine cold since the heat makes the metal expand slightly. Another option would be a pipe wrench but the Vise grip should do it. Good luck.
Vise grips!!! to get old one off.
I just put on one of those quick change plugs. Picked it up at Advance Auto Parts. You only have to torque the plug once, then drain tube threads on and pushes on value to release oil. There is cap to cover valve that only need to be finger tight.
Fram Oil Drain Plug
I forgot which size but I bought two and returned the I didn't need.
Fram Oil Drain Plug
You'll have to see what the threads look like once you get the old bolt out. As for a replacement, you may want to consider a Fumoto valve. We have one on all of our vehicles and most of our friends have them and they make oil changes quick & easy and we have never had, or heard of anyone that had had, any issues with them. Plus you wouldn't have this problem again
I never understood why in the hell someone would crank the snot out of an oil drain plug to tighten it. Especially in the MINI's case where it has an o-ring seal and is threaded into an aluminum pan. Spin it in with your fingers then give it a light snugging with a short wrench and it's done. It seems dealers and oil change houses are the worst for this phenomena.
The first thing to try is a proper 6-point socket and ratchet to loosen the plug. If the socket no longer will go on or slips, then vise-grips should do the trick. I would purchase a new drain plug to fit before removing the mangled one.
Thanks, Everyone for your help. Once I get the old plug out. The quick drain valve or fumotovalve sound like the way to go.
I'll try the Visegrip and hammer tapping method first. If that doesn't work, maybe I'll try "Bolt-Out" from Sears. Has anyone every tried "Bolt-Out"?
Will a Metrinch wrench work on a stripped bolt head?
Thanks again for all the help.
~Paul
~Paul
~Paul
~Paul
id just get a fram quickchange valve, its easier anyways.... (and cleaner)
09R56
11-16-2022 10:49 AM
07-16-2020 12:54 PM
08-19-2015 08:27 AM
