Aux Gauges Oil temp bouncing around
Hi
I rarely look at the aux gauges because they are too low and out of the way but I know normally the oil temp never moved, state between 90 - 100.
Today, from the moment I drove away in a cold car, the thing was sitting at 150, then bouncing up and down depending between 100 and 150. Cruise steady an it would go up to 150. Bounce the car faster of slower with gas or brakes and it would go down.
Sounds like a loose wire to me and the oil was changed about 200 miles ago.
It does not look like the real temperature as the is no way physically possible for the temperature to flunctuate to such a degree in 1/2 sec.
Any thoughts?
Any thoughts?
The temp sender replaces the oil drain plug on the MINI aux gauge set. The wire needs to be removed when the sender is removed to drain the oil. Most likely the wire was not plugged in securely. It's a simple matter to get under the car and check this wire if you dont want to take it to the dealer.
07-16-2020 12:54 PM
finn
08-21-2015 07:59 AM
tylewis
08-18-2015 06:53 AM
