Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
2002 Mini Cooper, and the A/C works sometimes, and never when you really really need it. I tried the disconnect the battery thing and it works for a few hours. Any other ideas?
cud be alot of things if you didnt fix it yet.......im guessin you might be low on freon which wont let the system turn on cuz ull blow the compressor without the level of freon the system needs to run.
does it not work after runnin' around for awhile or is it more or less at any given moment. like even if the car is cold.
Easy way is to have a friend or your local shop put your car on the machine and do a system check to see how much freon you have in the car and you can go from there with the diagnostic.
