whats this sound (short vid)
Old 08-27-2005 | 02:29 PM
Tüls's Avatar
Tüls
Turbius Maximus
Originally Posted by vegasdan
Many MINIs have this problem, mine from new. It's a seal in the fresh air system that is buried behind the dash somewhere. The reason it can vary when it appears is that it will start at lower speeds if you are driving into a head wind. My dealer shrugged his shoulders and wouldn't even take the car out for a test drive to determine. MINI has to know about this but will not issue a recall to fix. It stinks on a 25 grand subcompact to have this shreeking noise when you drive. There is nothing you can do to the A/C controls or rolling down windows that will stop it.
you know MLEs mini was making a quite version of this the other day...I didn't even think about it...all I did was turn off the resirculation setting on the AC and it stoped...
  #27
Old 08-27-2005 | 04:21 PM
CARdiac's Avatar
CARdiac
Considering the sound comes up at excessie speeds, I am not sure I want the dealer testing it
  #28
Old 08-27-2005 | 08:13 PM
btal40's Avatar
btal40
thanks a bunch guys!! yeah, im dropping my car off for some other stuff tuesday but dont know if i feel like bringing it up, hope its not the BP valve ( think i should ask?) if i tell them about it, i dont know how to recreate it for them anyway on a test drive haha. roehrigs01, i think ill have to divert the mod money to therapy cause of long trips with my girl, haha. the more capri-sun i feed her the less she talks
  #29
Old 08-28-2005 | 11:39 AM
vegasdan's Avatar
vegasdan
The best way I've found to "eliminate" the sound is to turn up the radio.
  #30
Old 08-30-2005 | 02:45 PM
SB's Avatar
SB
Today, after owning my MINI since May 03, I heard this noise. I was running about 50mph and a crosswind, remnants of the hurricane, hit my car and I heard the whine/air sound. It came and went a few times on my way to work. I've been in the same situation several times over the last two years and never heard it before today. My vents/re-circ setting changed nothing no matter the settings.
There has only been one change on my car in the last week. I have an 03 and the foam under the cowl vents was worn so I went to have it replaced under warranty. Instead of replacing the foam, they replaced the vents with the 04 and newer style vent. Could this be the reason? How many here have heard this sound and have the older style cowl vent.
Maybe you could take the vent off or do something and try a test run.
  #31
Old 08-30-2005 | 06:10 PM
Tüls's Avatar
Tüls
Turbius Maximus
interesting...and an easy enough test....anyone?? I have the newer ones
  #32
Old 08-30-2005 | 07:34 PM
motorsports3's Avatar
motorsports3
My car has the same thing. I only get it aroung 110. I first thought it was the wiper blade. Took the blade off and it was still there. I think it is the vent.
Another method to try an eliminate it would be to start taping over things. Cover the vent so it is completly covered and no air can get in it. If the sound is gone there is your problem, if it is still there then move on and tape something else. If I wasn't so lazy or maybe if that noise bothered me I would try this.
  #33
Old 08-30-2005 | 07:51 PM
apexer's Avatar
apexer
Had simular sound couple of times. Figured out the window was not all the way closed
  #34
Old 08-30-2005 | 08:14 PM
btal40's Avatar
btal40
haha my sounds deff coming from the bonnet area. i could do the tape thing, but have no where around here thats safe to get up to speed but then, you may ask, why worry about the noise?? just cause i know its there
  #35
Old 10-16-2005 | 07:08 PM
bodinski's Avatar
bodinski
I just got my car back. The dealer replaced the heater box to fix the recirc-whistle that so many have experienced. That seems to have been a success, but I got the choo-choo like noise (just like in the vid) @ ~ 95 again today. Tried fooling with the AC & wipers but neither seemed to have an effect. I wonder If it could be the seal under the A-pillar vibrating. I'm gonna pull my A-pillar cover & take a look.
  #36
Old 10-17-2005 | 03:13 PM
CDMINI's Avatar
CDMINI
Good foam earplugs, always works on the MOTO, god knows wind blows all around my head at 80mph+on those things. I think the MINI will spoil me and have a overall detrimental effect on my "roughing it" gene
  #37
Old 12-05-2005 | 04:24 PM
bodinski's Avatar
bodinski
Found It!
In my case, it's the sunroof. If i vent it even slightly, the noise stops immediately. Closing it brings it back. One of those tacky deflectors would likely fix it, but I think I'll let it ride & just keep it under a hundred.
  #38
Old 12-08-2005 | 09:16 PM
btal40's Avatar
btal40
nice job bro, did you try the a pillar first? me no have sunroof so im still curious? one day im going to go berserk and pull my car apart and take a few runs and add stuff each time to find that it is
Colt45Magnus
08-27-2024 06:03 AM
tylewis
09-06-2015 02:07 PM
jesterofatlas
09-05-2015 12:23 AM
Sailorlite
09-04-2015 08:03 PM
wildwestrider
09-04-2015 07:25 AM
