Direction Signal Lense Replacement
Old 01-27-2003 | 11:12 AM
REITT's Avatar
REITT
Unfortunately, I had some road trash "kick-up" and knock out the left-hand directional signal lense...the lense is in multiple pieces. The dealer told me the front bumper/valence assembly would have to be removed to replace the lense and it will cost a couple hundred dollars + to replace it!! The bumper has to be dropped down???? Can someone confirm this. Thanks
_________________
Tom
FOLLOW UP: I got the directional light and it was about $25.00. It comes as a complete package including the 2 bulbs. The lense is sealed to the body of the light assembly. It took me about 30 minutes to put it in and it was pretty easy. I removed a handful of screws that were easy to get to. The toughest part was to unclip the upper, middle portion of the bumper section without breaking it. I saved about $150.00 dealer labor cost. Thanks again to those that helped!! :smile:
Old 01-27-2003 | 01:13 PM
rataha's Avatar
rataha
I had the same problem. Drivers side also. I ordered the part. about 25 bucks. It is one unit. no replacing the lense. I have not done it yet as it is cold and snowy in Iowa. It does appear that the front bumper trim will have to come off. I would have done it right away to prevent damage but since it is all one unit no further damage will result. As soon as it warms up I will replace it. If you can be patient I will let you know how difficult it is.
Old 01-27-2003 | 01:16 PM
dave's Avatar
dave
pug poo picker-upper
I had the same thing happen on my trip to canada. You have to remove the bumper cover and disconnect the wire harness in order to get at that assy. All told it took me about 45 minutes.
Let me look around when i get home to see if I took any pics that might be useful to you.
Dave
Old 01-28-2003 | 10:27 AM
REITT's Avatar
REITT
Thanks for your input!
Old 01-28-2003 | 10:29 AM
REITT's Avatar
REITT
>>Dave
Thanks for the input Dave. I'll look for your pictures. I'm a "handy guy" and if it's only 45 minutes, I can tackle that myself.
Old 01-28-2003 | 09:40 PM
bbmykal's Avatar
bbmykal
WOAH! I can't believe that happend to all of you. Now I am SO glad I got the prottective 3M lens covers. I got them from Moss primarily for the headlights, all that glass worried me a bit. It also came with covers for the front lenses as well.
Old 01-29-2003 | 05:56 AM
rataha's Avatar
rataha
Don' t think that would have saved mine I heard it hit and it was real loud
boostedhaze
01-02-2018 08:26 PM
Rai1gun
R60/R61 Stock Problems/Issues
01-11-2016 06:52 AM
HCClubbie47
R55 :: Clubman Talk (2008+)
08-24-2015 03:16 PM
skippermini
08-13-2015 07:13 AM
nismo4life
08-05-2015 09:31 AM
