Steering fluid level???
I would think at the lowest level on the stick. Basically you want enough in the reservoir that there will not be any air drawn into the system. If your fluid is disappearing but not visibly leaking there is a chance it is leaking into the steering rack boots. Also, do not use common power steering fluid. The MINI takes a synthetic fluid called Pentosin CHF 11S.
Originally Posted by namwob
Look under the hood. You'll find it. I believe the hood latch location & res.locations are both in the owners manual which you have already located.
EHHH wrong! I know how to open the hood and the power steering reservoir location is NOT in the 2005 Owner's Manual.
Thanks for your help Greatbear.
You will use less than a full can, CHF-11S can be found cheaper than dealership at NAPA, ~$20 OTD for a can.
Thank you wrh3. As far as I uderstood you it goes in retail sale in cans with capacity of 1 quart? They don't have this fluid brand at local Napa stores in Gainesville, Fl.
P. S. Actually it's my daughter's manual transmission mini cooper. She asked me to help her. Its steering pump went to deep south. I'm gonna disassamble it and try to clean it and whatnot.
Yes, retail package is can of 1 quart.
Your local NAPA may be able to order it for you since it is a catalog item and have it in a day or two: http://www.napaonline.com/Search/Det...11S_0058582551
I have also seen it at Car Quest and Oreilly Auto Parts for a little more, call around to some of the local McParts stores.
It's NOT in the MANUAL!!
Thanks.
Problem Solved
Just got mine back. Hose Clamp (part #3211113134) at pump on hose leading from reservoir was loose. Mechanic cut clamp and replaced with new hose clamp. Tightened, cleaned, all done. Steering nice and smooth again. $75.00 labor. Plus the $20 I paid to buy the CHF 11S fluid.
Hope this helps others.
If it was stuck on...the electronic have failed...new is really the main option...
If it cuts in and out, then a cleaning and maybe new brushes may help...
Rebuilders can replace the hydraulic pump, but the motor (if it cuts in and out, the windings may be shorting out) is not rebuilt, and the computer/circurit board is not changed...just cleaned.
So if your rebuilding/cleaning does not work, IMO new is the only real option.
Many thanks guys. We'll go inside and see where it takes us. Happy Cristmas everybody. I'll keep you posted.
P. S. So far, these pump star key screws, they're very stubborn, I screwd up one of them all around, so I grooved it with a saw, and used a regular screwdriver to unscrew it. Really not much of experience of this kind. Joe.
Well I got to the brushes today. Used 3-jaw puller set to pull off upper motor cover with inserted bearing in it. Commutator or, Collector, whatever you call it is pretty much worn out, has deep grooves in it, brushes look like there is still some life into them, even though they are half worn out. Bearings look fine, like for another 30-50 thou miles to run. But then again, who knows...
I tried to get to the electronics stuff, which as people say located under brush plastic basis, unscrewed 4 tiny screws, but something is holding it adhered to the motor cover, can't lift it up, afraid to act with a blind force, gonna brake it. Now very upper part where the pump itself located is so far not disassembled by me. Its plastic cover sits very snugly on the metalic body, once again don't know how to take it apart. All in all, machining the collector doesn't seem to me to solve the problem. Being completely in dark about the pump itself and electronics doesn't seem like to get the pump fixed to work on the collector alone and with all that probably a better idea to buy a completely new one. We'll think it through. Joe.
888.280.7799 | 6am - 5pm PST
patsum
26
05-29-2021 06:29 PM
Supertractor3
04-07-2017 11:16 AM
molala
10-02-2015 01:53 PM
