Dumb question about Rhino ramps
Old 09-22-2005 | 11:26 PM
cantdrv55's Avatar
cantdrv55
Do you guys drive up on the ramps or jack up your cars and then lower them on the ramps? I've tried driving up on them but I tend to scrape the spoiler or shoot the ramps across the garage.
Old 09-22-2005 | 11:28 PM
J0kER's Avatar
J0kER
are u sporting a lowered stance??
Old 09-22-2005 | 11:33 PM
cantdrv55's Avatar
cantdrv55
Sorry. I haven't tried driving up on them with the MINI. I scrape or shoot them off when I drive up with the 911s. So now, i just jack up the cars and lower them onto the ramps. Anyone have trouble driving up on them with their MINIs?
Old 09-22-2005 | 11:38 PM
J0kER's Avatar
J0kER
never had this happen
i dont have the rhino's but have a set from 'Advanced auto parts' and they r plactic so they dig into the ground better im assuming rhino's are not plastic
Old 09-22-2005 | 11:40 PM
cantdrv55's Avatar
cantdrv55
Rhinos are plastic too. Hmm, maybe I'll look into other plastic ramps.
Old 09-23-2005 | 12:03 AM
chrisneal's Avatar
chrisneal
I believe that there are several different models of the Rhino ramps with varying angles, so that they can accomodate cars with lower ground clearance. I can easily drive up onto the standard ones with my Cooper.
Don't forget to chock the rear wheels while you're on the ramps.
Old 09-23-2005 | 12:18 AM
Wenzor's Avatar
Wenzor
I use rhino-ramps, but with a piece of 1"X4" wide wood to roll up on. This causes no scraping. My MCS is lowered.
Old 09-23-2005 | 04:30 AM
daleCarlsbad's Avatar
daleCarlsbad
I have the steel ramps. They used to skip forward when trying to drive up, but I put a small piece of thick rubber under the forward edge and now they are fine.
As for scrapping the low spoiler, I place a short wood plank at the beginning of the ramp to lessen the steep angle of the ramp. The tire easily rides up the wood (spoiler now clear) and then onto the ramp it’s self.
Simple physics.
Old 09-23-2005 | 05:36 AM
Rev. Limiter's Avatar
Rev. Limiter
Put the ramp in place in front of the front wheel. Straddle the ramp, grab the two side holes, slide the ramp back ~12 inches and then rapidly CRAM the ramp under the tire. Make sure the alignment of the ramp to the wheel didn't change. Repeat for the other front wheel.
The tire will pinch the ramp, and make driving onto the ramp easier without shooting it across the floor.
And don't forget the chocks for the rear. :smile:
edit: the above works for my Rino Ramps... Yours may vary. Batteries not included, close cover befor striking, side effects may include nausea, when all else fails, RTFM.
Grizld700
12-30-2015 11:47 AM
donniedarko
10-21-2015 02:15 PM
embiggenedmini
10-15-2015 01:36 PM
marc0011
09-10-2015 11:04 PM
Panik
09-09-2015 09:36 AM
