MCSa WARNING!!!
MCSa WARNING!!!
Today a drive shaft dropped out of my 05 MCSa. It has less than 5K miles. The dealer told me that he had priviously been asked by MINI if he had any experience with this happening....up until today he had not.
It occurs to me that this is a very dangerous condition. The car stops dead and cannot be moved. Had this happened in traffic the result could have been tragic. If MINI was aware of a potential problem they should have voluntarily sent out a safety recall.
I recommend that If you have a MCSa you contact your dealer immediately and inquire about this potential hazard.
At this point, you don't even know what happened. Urging others to action seems pointless. I understand you're upset, but come back when you know something.
All I'm saying is that the dealer had been asked by MINI if such a problem had occurred in his dealership. This sort of implies to me that they were at least aware of a potential problem.
As an update on repair: The shaft dropped out on the wheel side & the service manager assures me that the tranny is OK.
The dealership has been extrememly cooperative in fixing this problem & the car should be ready today.
The same thing happened to a local member (driving an MCSa) during an AX run about two months ago. When it popped out at the finish line he free-wheeled it back to parking. No power to the drivetrain at all. The dealer had never seen nor heard of the problem before that. These are the only two incidents I've seen on any of the forums.
There may be a problem, it may be very unusual. There's no point in making assumptions or stating incorrect facts.
As I have said before I had a loss of power happen five times in a 2005 MCA. It was scary but no parts fell out. I got a recall letter from Mini last week on this but I had my car in for service two weeks before and they did the fix. I have not had any more repeats so far. I read on another forum that the loss of power may be caused by hot climates. I live in one. I would drive out of my open parking lot at work one block (after often sitting all day in 100 degrees or more) and suddendly the car would not move. Fortunately if I turned the motor off and then on again it would move and i could make the 45 minute drive home okay. It never happened in the city in which I live but I park underground so my car is not hot when I drive out of that lot. ski
on
Crispy Mini???
what is the latest with the crispy mini? Have not seen any updates on your site.
Thanks, Just Curious!
Bill
Bill
Originally Posted by Jonauto
You say the drive shaft poped out on the wheel side? the boot must have come apart... is there any difference in the driveshafts of the manuals and autos?
...it was the passenger side output shaft that had popped out of the transmission through the bearing carrier.
This was repaired immediately by the dealer and the car is now "as new" again.
cheers,
Lloyd
Passenger Side Axle is the problem!
Racoman,
Add me to the list of MCSa owners that has suffered a passenger side axle popping out in my 05 Cabrio S. It occurred with less than 1,500 miles. See my thread, https://www.northamericanmotoring.co...ission+failure
The Service Advisor emailed me today about what the problem was. Now my concern is, "will it occur again?" Good call, racoman!
Charlie
Charlie
Not to be alarmest, but what if you or a family member pulls out in front of that big truck coming down the street & the axle goes pop??? Seems like a pretty serious saftey issue to me. I'd recommend that you let NHTSA know about your problem. If enough people let them know BMW would have to fix it on all cars not just of cars with failed axles.
Just my .02 here & worth every penny you paid.
Chuck
Chuck
