need install instructions for belt tensioner on MCS
Old 10-05-2005 | 12:25 PM
dominicminicoopers's Avatar
dominicminicoopers
I need install instructions for belt tensioner for the MCS. This is the one that sits just behind the supercharger. I also have a new belt. I heard changing the belt is pretty easy, but I don't know how complicated the belt tensioner is.
Here's a pic I found. It is the object that has the spring part and the bracket arcs over the top of the pulley.
I presume I will take off the motor mount on the passenger side of the car. Do I need to lift the engine like is done with pulley swaps?
Old 10-05-2005 | 01:51 PM
SRTech's Avatar
SRTech
I just replaced mine. I originally took the bad one out without jacking the engine. A complete PITA since there is almost no room to work. I also don't think I could have done it with the stock pulley since it takes up more room. When I installed the new one, I jacked the engine as I did with the pulley install which made it a lot easier and took less time. :smile:
Steve
Old 10-05-2005 | 03:00 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Dom, I did mine a few months back. Tried without jacking up the motor, got it loose, but there was no room to get it out. Go a head and jack up the motor, it's not that bad, read Randy's pulley install instructions, tells you how.
Todd
Old 10-05-2005 | 04:55 PM
dominicminicoopers
Thanks guys for the help. I'll look at Randy's instructions to jack the motor.
sevin
02-01-2016 12:30 PM
iamcamkeenan
08-10-2015 04:31 PM
08-07-2015 10:51 AM
08-07-2015 09:10 AM
08-07-2015 09:02 AM
