Brake drag
MINI Cooper Service Manual 2002, 2003, 2004 from Bentley Publishers page 340-30:
Parking Brake
The parking brake is operated from the parking brake lever by two Bowden cables, with a left-right compensator fitted between the brake lever and an adjustment nut under the lever in the center console.
The parking brake stops the car through the rear caliper piston acting directly on the rear brake pads which, in turn, presses on the brake rotors (discs).
The parking brake is self-adjusting, with the adjustment being made at the caliper piston. A special tool is required to wind back the piston when fitting new pads.
Page 340-31:
Parking brake, checking and adjusting
Check parking brake as follows:
Release parking brake lever. Check to see that there is no drag at rear wheels. (My bold font...)
Pull up brake lever 1 notch. Again check to see that there is no drag. Parking brake warning light, however, may be ON.
Pull up lever 2 notches. Check to see that there is a slight drag at each wheel and that parking brake warning light is on.
Drive vehicle and pull up on parking brake handle. Check that rear wheels lock up.
I say again. You may want the MINI sevice department look at your car. :smile:
Parking Brake
Page 340-31:
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 07:27 AM
slitcher
09-07-2015 07:17 AM
Tinklespout
16
09-06-2015 12:39 PM
PelicanParts.com
Tires, Wheels & Brakes
09-03-2015 04:22 PM
