Why is a jack supplied with run-flat tires?
I picked up my new MCS Friday. Later, as I inspected the boot contents, I was surprised to find a tidy package containing a sissors jack. I'm wondering what purpose that serves since the MCS has 17" run-flats and no spare.
Did anyone else get a jack with their run-flats? I'm wondering if I should have gotten a tool kit instead.
Thought I'd ask before I contacted the dealer.
For some reason, it seems like they started putting jacks in the 2003 S's. I have a late build 2002 and didn't get a jack...but would have wanted one for doing basic tire changes (e.g., winter change-overs). It's interesting to see that they're really providing the jack now as it seems that this was sort of hit-and-miss for the first 2003's.
Why do we park on a driveway and drive on a parkway?
Why is Greenland called so when it's covered with ice? Why is Iceland called so when it's green?
Also.....
If you wear a dinner jacket when you have dinner, and wear a smoking jacket while you're smoking, and a dressing gown when you get dressed... then what's a wind breaker for?
OK I see the jack would be handy for rotating the tires if I wanted to do that more often the the scheduled service calls for.
Thanks.
Also.....
Thanks.
>>Thanks.
Ahhh, you're in TX. I guess you don't need to do seasonal tire changes down there. BTW, I agree with DID re. a floor jack being a better option. I suppose I'm only carping about the fact that you 2003 folks are getting something for "free" that I did not. Oh well, I have the rear power outlet and you don't. And boy is THAT a useful option
I got one in mine...August delivery. As you said don't really need it unless you just want to jack it up for fun if your not at home I use Rhino ramps and floor jack/stands at home. Only thig is mine isn't a sissors jack it's some weird kind of jack that sits on a angle and looks like its going to tip over and damage the car. So I say leave the Jack Off....the MINI
>>Also.....
>>Thanks.
and..
Why does a 7-11 have locks on the doors if they are open 24x7?
>>Also.....
>>Thanks.
and..
I think the jack that comes with the MCS works quite well. One thing to note is that the jack/jackpoints are designed to work together. I have a floor jack in my garage, but still decided to use the MINI jack last night when I put my 15" Holeys (winter tires) on. No complaints. That kit is nice and tidy - jack, folding chock, and tire iron. Worked well.
Also, someone above mentioned that they thought they should be getting a tool kit with their MCS rather than a jack kit. Well, my MCS came with both. The toolkit is in the compartment on the left side of the boot, and the jack kit was strapped to the tie-down points in the boot.
Because it is unlikely that a jack without a spare tire is going to help me in a situation that I cannot get out of with the run-flats and a can of fix-a-flat, I have actually removed the jack from the boot and have placed a small foot pump in its place.
When filling a run-flat on 17" wheels, it takes about 15 pumps to add 1psi, and it is a small and reliable (MINI) tool that used to be included with the tool kit in some old land rovers. Funny that BMW gave us a useless jack instead of this little cool thing that would have been so perfectly "MINI".
~Andrew~
~Andrew~
The rear power outlet is handy for plugging in the electric tyre inflator after you wear out the run-flats and replace them with some nice sticky hi-Performance skins. A mobility kit containing a tyre plugging tool and a small compressor.
You can fit the jack kit into the compartment on the right side if you remove the chock out and then balance the jack on top of it.
I posted some pictures in my gallery on MINI2.
07-16-2020 01:54 PM
ltjpunk7
09-06-2015 08:32 AM
