How do you determine if a O2 sensor is bad?
It should throw a CEL when it goes bad, then a quick plugin of an ODBII scanner can tell you usually if it's the O2 sensor and which one.
The other way is your mileage usually will drop quite a bit..
I've usually gotten about 80k miles on o2 sensors in all my other cars before they go.. and even then it's often just a ground issue.
