What's that "releasing" feeling when slowing down?
Crazy thread title, but I couldn't think of anything better.
OK, you're in 2nd gear and in traffic. Things are slowing down so your car has to go slower and slower. You are not on the gas nor have you depressed the clutch yet. As the car gets slower, suddenly there is this feeling of "release" almost like you have depressed the clutch (but you haven't yet---but of course, you have to soon ...).
What is doing that?
This has always happened even with my other cars.
Just curious to know what the clutch/transmission is doing? :smile:
What is doing that?
I complained about this initially a few years ago on my 11/02 build 03MCS. I drove with shop foreman in my car to show him, & we also rode in several showroom cars that did same thing. It was there with version 32 stock software, & also with version 36 & with version 39 mandatory upgrade. Has not changed with GIAC install, VGS or anything i've done. I live with it and try to compensate but it is annoying.
Originally Posted by ofioliti
Hmm interesting.
Yeah, sometimes I can prevent it by giving it just a little gas (and hoping the guy in front starts rolling soon!)
I don't see it too much as a 'problem.' I had the same effect in my Subaru and my Toyota pickup.
If Dr. O's (second post above) explanation is correct, then it should be normal and should be in all MCSs. Although I suppose the computer could make it a smoother transition from 'no gas' to 'with gas.'
I have felt this in all of my manual cars as well.
I have always thought that it was the engine speed matching the speed of the driveline.(RPM"S) The RPM it ocures at would be different for each gear.
During engine braking, once the engine has reached the driveline speed, it causes that little bit of, where the engine is no longer braking, the feeling of no resistance, and will eventually lug, making the engine turn slower than the drivline speed.
It wouldnt be the ECU telling the engine to go from idle to throttle. As you let off the gas pedal a long time ago, the TPS sensor already told the ECU that the throttle plate is closed when you let off of it. If you leave the clutch engaged, the engine would eventually lug itself to a stall. Maybe the effect is intensified due to the SC?
Am I making any sense here?
Of course this is all my opinion.:smile:
The Mini does interesting stuff
Matt
What is the "driveline" as opposed to wheels, gears, clutch, engine, etc.? Aren't wheels, gears, clutch, engine, etc. all rotating "together" when the clutch is engaged? What is this 'driveline' that is rotating differently?
(Please educate me! :smile
There is injection when there is engine braking. Another reason why automatic trans get worse mileage than manuals. It takes gas for engine braking. When you disengage the driveline,clutch, you are making the brakes do the work,not the engine. So they get better mileage. Yes I understand there is also driveline loss in a torque converter,this contributes to the mileage as well.
When a trannny is spinning faster than the engine, it is called overdrive. yes thats whats going on in the autotrans when it shifts into overdrive. It is so common these days, its not really colled overdrive anymore.
The driveline consists of the tranny and the halfshafts ect. When you are coming to a stop,or a slow in this situation,eventually,the driveline, matches the engine RPM.So the engine is no longer creating braking force. If you downshifted into the next lower gear, the whole process will happen again.Which is why I stated it will happen in all gears. It is a matter of what RPM your driveline is at compared to the engine RPM.
OK, K4KAS, I think I know what you mean. That can't be it if I understand you correctly. The engine revs do/must match the transmission (driveline) as long as the clutch is fully engaged (i.e. not slipping). When I am slowing down and the clutch is engaged all the driveline elements are moving 'together' and there is no 'catching up' of certain parts. So, I think Dr. O's explanation makes more sense.
K4KAS nailed it. Explaining it is not that easy. I have noticed it in all manual vehicles I have driven. The lighter the car the more noticable it is. Especially a Formula Ford! To me it was always a sign I was in a gear higher than needed. Kenchan has the right idea with a correct heel and toe downshift you miss the whole engine/driveline lurch, or like others have said, just depress clutch a little sooner.
I'll take it over an automatic any day
I just read the "Fuel Injection" section of my Bentley manual, and sure enough it says that the ECU reduces the fuel feed when your off the gas (of course), but provides more fuel as the revs approach idle speed. So, I'm pretty sure that's what I'm feeling. So it is not so much a "releasing" as a mini "surge" as the engine is receives more gas.
wildwestrider
12-27-2015 09:20 PM
wildwestrider
09-04-2015 07:25 AM
Ladybug-S
09-01-2015 08:07 PM
