Starter motor nearly causes fire!
Here is a weird one that could have been MUCH more serious than it turned out to be.
Made a run to the post office (5 miles), and on returning to my Mini and restarting my 2003 MCS I got about 100 yards, noticing a chug chug chug pulsing sound coming from the engine compartment. I pull over, put in the clutch, put it in neutral and there is a loud, continuous chugging or pumping sound coming from the engine! I turn the key off---but the sound continues! Upon opening the hood I can tell the starter motor is engaged and turning the engine over! It is not turning the engine over like when you start it however. This is more of a slow pulsing, not a steady running of the starter motor. Then the smell of burning wires. Then the smoke begins! I frantically open the trunk to get my tools and undo the negative lead of the battery, BUT, there is only the jack and tire iron in the Mini tool kit. (Is that all we get?!?) Now it's serious panic time. Smoke is pouring out of the engine compartment! I grab the negative battery lead and frantically start working it back and forth, where the lug is bolted to the frame. In what must be the longest minute of my life, the lug finally fractures and the negative battery lead comes free. The smoke starts to subside, and there were no visible flames ever seen coming from the engine compartment.
Lesson 1: Carry a tool that will definitely disconnect the battery connection ASAP. (even if it's a cable cutter. I would have used a cutter here in a second rather than mess with a wrench! Trust me on this one!)
Lesson 2: Carry a fire extinguisher.
I have never heard of this happening before, and I sure hope nobody else has this happen to his or her Mini.
My Mini now sits at the dealer undergoing a complete new main wiring harness/starter motor installation. Thank goodness this is under warranty as the dealer has said that the starter motor was the culprit. (I was thinking a stuck solenoid---maybe it's integral on the Mini starter motor).
Hope this helps....
Marty
Hope this helps....
Marty
Les,
I think it was a slow process and not "instant" flames. (I never saw flames). I think the starter motor wiring probably handled the current fine for a minute or so, but I don't think it's designed for continuous cranking for five minutes! I'm curious what actually failed in the first place. Maybe someone here with more knowledge of the Mini starter motor will be able to inform us all about what could have failed.
Marty
Marty
Unusual failure!
It could have been a welded solenoid. It could have been failed electronics driving the solenoid ... I have heard of one MINI that (rarely) keeps the engine running when the key is switched off, even removed! Not quite the same fault, but maybe related ...
Glad you and the car are basically OK; the dealership should be able to sort it.
One question: when you got out & left the car to go in to the PO, was the car making the noise then? If there was a solenoid failure, it would have stuck from the last use - which was presumably when you started the car at home before the drive. So you would have heard it when you stopped the engine.
Originally Posted by Yfoiler
Les,
Marty
Marty
...Les
Originally Posted by GBMINI
Unusual failure!
>>One question: when you got out & left the car to go in to the PO, was the car making the noise then? <<
Thanks guys,
Marty
