Have plugs, about to get wires/coil pack
Right now I have Denso 1 step colder plugs, alta intake, magnaflow exhaust, alta 15% pulley... I'm about to purchase Kingsborne wires and the Pilo coilpack (let's not turn this into a debate about different brands of wires, coils, etc..) and I was wondering if I needed to gap the spark plugs further? When I put them in I just put them in straight out of the box, as per Chad's (@ Detroit Tuned) advice. Should I gap them? If so, to what?
who said..
Chad didnt tell u to gap them?right********correction read ur post again********saw that u stated "As Per Chads advice"
Originally Posted by TwOMINIs
Tried to gap mine...broke the tip right off. !! Then, read on here that they are pre-gapped...whoops...
Vendor - 15 Years
Originally Posted by MiniMe05
Across the board there was a .002-.005 gap variance within a lot of 8 plugs.
There is a bunch of info here. You go not have to regap them unless you really getting into special settings on your motor with special gas and boosts. For what you have on your car, keep the same setting. But while you’re right there when the engine is cool, make sure they are tight (22 ft. lbs.).
right, but then if they are not all even, and need to be gapped (Denso's in this case) What whould one do, as they probably wouldn't like to gap it and have the tip break.
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 07:27 AM
patsum
26
05-29-2021 07:29 PM
