Help engine misfire at WOT in cold weather!
Was driving home today in the fog and it was around 2 degrees, i floored it to get past a fiesta when the ses and asc light appeared ...then i was in limp home mode 60mph with 255 horses under the lid was pretty sh#t
Anyway pulled over and checked the code got P0300 Random/multiple cylinder misfire, cleared it and restarted .....everything was ok again then floored it to check then all of a sudden the same happened .
So i drive the remaining 40 miles steady with no probs .
Has anyone else had this? ive never had it before and seems to be happening only in cold/dense weather at WOT.
Will check the plugs,leads,wiring out tomorrow...any ideas would be appriciated.
Cheers,Rick.
Cheers,Rick.
Originally Posted by Rickkys'S
Was driving home today in the fog and it was around 2 degrees, i floored it to get past a fiesta when the ses and asc light appeared...
Rich
on
Originally Posted by Maximusmini
I don't think your Bypass Valve for the supercharger would have caused such things.. You said 2 degrees outside! Thats what the temp was when I broke my Halfshafts in the middle of Wisconsin on my way back to Michigan.
I would consider checking to see if you have moisture in your fuel tank. Going WOT might introduce just enough water into the system to cause a missfire, where "normal" driving keeps the A/F ratio in a burnable range.
If you garage your car you might end up with a wide temp differential that causes water to condence in your tank. Pour in a can of dry-gas and get a full tank fill up at a quality station and see if that helps.
Cheers,Rick.
Cheers,Rick.
07-16-2020 12:54 PM
minicoclub
11-11-2015 07:25 AM
Powershift
08-16-2015 05:14 PM
