Old vs New OEM crank puley
Old 12-07-2005 | 12:16 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
Here are a couple shots of the new and old OEM pulleys. They are definitly different!
Although if you look at it there is very little dampening ( rubber ) on the new pulley
new is on the left.
Attached Thumbnails Old vs New OEM crank puley-dsc00756-medium-.jpg   Old vs New OEM crank puley-dsc00757-medium-.jpg   Old vs New OEM crank puley-dsc00758-medium-.jpg
Old 12-07-2005 | 12:54 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
I just weighed the 2 to see just how much difference there is.
Old pulley = 7.2
New pulley = 5.1
So there is roughly 2 pounds difference.
Old 12-07-2005 | 02:06 PM
norm03s's Avatar
norm03s
Cool, Thanks for the info
Old 12-08-2005 | 11:56 AM
Jdewey's Avatar
Jdewey
Crank Pulleys
Are they both from the same model car?
An MC has a single isolation crank pulley, but an MCS has a dual isolation pulley.
This was to move the resonance of the Super charger, drive belt and pulley to an rpm below the normal operating points of the engine.
John
Old 12-08-2005 | 12:01 PM
micahbones's Avatar
micahbones
I think the change to the lighter crank pulley was made in '05 -- here's an explanation from Randy Webb.
Old 12-08-2005 | 12:47 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
they are both for th esame car, just a new version vs the original one. If you go into the dealer and ask for a crank pulley you will get the lighter one as it has replaced the heavier one.
Personally I have tried the 3%, the 0% light and the lighter stock one and I perfer the lighter stock one, smoother throughout the range and idle is smoother. At least in my car, I have all the motor mounts upgraded with powerflex
Old 12-08-2005 | 06:08 PM
ScottinBend's Avatar
ScottinBend
Have you got a part number for the new one?
Great post.
Old 12-08-2005 | 06:12 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
11237514461
That is the ONLY part # for a crank pulley now. The old one was dropped and the number replaced the old one. I looked at an 02 and an 05 and they list the same # that I posted, and that is th eone that weighs 5.1#
BernieCoop
09-10-2021 04:15 AM
ej
11-17-2015 10:21 PM
mikeson
09-06-2015 07:21 AM
M7Speed
09-03-2015 08:48 AM
