Coil pack question....
#151
Interesting fact about the stock coil is that it is rated at 40k volts, not 36 like people have mentioned. Also, did anyone know that this coil pack fires two cylinders at once. And that the two cylinder spark paths are linked in series to carry the current flow. That means that one of the spark plugs in the series fires in reverse.
To me this means that ignitions wire resistance may be more important that usual.
Did some digging and found new and interesting (to me) information, straight from the horses mouth.
#156
http://www.msdignition.com/sci_4.htm
http://www.msdignition.com/pdf/62112_62152_frm25956.pdf
Links to MSD's site for the main info on the Ignition box and for the PDF of the user guide for the box.
Its really only nessecary if you want to presicely tune your car. The stock ECU does a decent job of handling the ignition for you on a mildy modified car.
If you were running nitrous or a TC, i could see the box as being benficial.
#158
It is MINI information, not proprietary, but where I learned it.
If you look at the plug at the back of the coil you will notice that there is only one power and two ground wires. How do you think the coil knows which cylinder to fire? How can it fire four circuits with only two grounds on the primary side? It doesn't (sort of) and it can't.
If you don't believe me (which is perfectly fine with me ) try searching for "waste ignition" systems.
Anyway, thought I would share this info as I have also become interested in this system.
#168
OK I need AT LEAST 10 people to get any discount from Summit!
Im not going to give a price yet because im still working on that and its still up in the air.
Lets just say it will be les than the discounted price Summit lists it as.
Lets start right now posting on who is definately interested in buying one, i need to get a count.
#175
on
Originally Posted by Will @ M7 Tuning
I'm pretty sure that they are talking about the interface terminals, not the plug wire terminals. The MINI uses flat terminals, and the coil is he same as the newer Neon.
and not
from http://www.modernperformance.com/dcx/msd_coil.shtml
and not
