OBDII Diag. Devices - Are they worth anything?
I've been having a time with my SES light coming on. Initially it was low oil. I bought a quart and put too much in (not on a level surface when filling). Then I let some out and achieved proper level. SES light stayed on and I want to know why. Saw the R5/EMX Diagnostic tool from Peake Research. Sounds like this will give you a fault code but don't know if these things come with a diagnostic reference list of some knid or any of the troubleshooting flowcharts, etc. Supposed to let you reset some things too but don't know if you could reset the SES light through programing with the dash buttons. What device is best for those of us that don't want to pay $100 every time some diagnostic light comes on to see what it is:impatient ?
BD
BD
Originally Posted by SumWon
I bought an Actron OBDII scanner off of eBay for not much.
It has been a big help in retrieving codes and reseting the SEL. Works in a lot of different cars too.
I got this one at Pep Boys for $80. Now I found it here for $62: http://www.amazon.com/gp/product/B00...nce&n=15684181
Works fine, comes with a list of codes, but the Bently manual codes are more detailed.
E-Bay listings: http://search.ebay.com/PocketScan-Co...5_W0QQfromZR40
I use Autoenginuity software on my Palm. Communicates via bluetooth and does way more that read codes.
on
Originally Posted by detlman
I just wish you could clear the airbag light with one of these.
But I have never heard of anyone testing it successfully on a MINI.
There were rumors that the Ross-Tech product BiM-COM would do it as well, but no solid proof there either.
I have a Mastertech MT-3100. Check it out at www.vetronix.com It's hardcore, but only the Global OBDII functions work on the European imports. I can do airbags and ABS codes on several domestic and Asian makes, but not the European cars. Can't will 'em all, I suppose.
Rawhyde
Rawhyde
You can go to AutoZone and they will come out and plug their reader into your car and give you the assessment. My experience; it depends on the person you get to read them.... some are good and have interest and experience. Others just want you to get outta their hair and leave them alone. I was successful in isolating a fuel injector gone bad on a Honda CRV.
The better guys can be REALLY sharp and get alot of exposure. The other type are worthless and should not be paid.
That is my 2cents.
-azminied
That is my 2cents.
-azminied
this is wat i use too. $65.
Originally Posted by motor on
yea I think I'm probably looking for something similar to an MTH, just wondering what the tool actually did compared to the rest
on
I think they are worth something.
Just wanted to relate a short story. I will always cary one of these devices with me now. I have a Peake, not "cheap" but does the job. Any way, for the story. I was attending a track day at Buttonwillow last month. I was having trouble trusting my brakes (wilwood BP-10 pads good on the street, bad on the track). Since my concentration was shot, I over rev'ed my engine a few times which sent it into "limp home mode" , check engine light came on and no power. Yah, it scared me at first, thought I might have messed something up big time. I waited for the session to end before driving into the pits at a top speed of 5 mph. This gave me a few minutes to think things through. In the pits I first checked my shorts then used my PEAKE tool to read the faults and reset the check engine light. I can not remember the fault exactly, but it was something to the effect of "error in the electronic throttle sensor". This confirmed my suspision that it was probably due to my bumping the rev limiter too many times and not catastrophic. Following that, I pulled the battery cable off for about ten minutes to reset the ECU and pulled a spark plug to see if the limp home mode soiled them. They looked ok, so I replaced the battery cable, the plug and tried to restart my MCS. NOTHING HAPPENED so I check my shorts again, tried the key one more time to make sure and it started up like nothing ever happened . I am thinking I may not have had the clutch in all the way the first time I tryed to restart the car.
All this to say, get a tool, the more features the better, it's worth it. The tool will save you money, time and head aches.
