Oil Catch Can problem?
Have a read on https://www.northamericanmotoring.co...ad.php?t=49645
Note comments by andy@ross-tech
- and -
Unless it is growing a tumor, it shouldn't swell up - I'd find out why it has, and why it isn't trapping much oil.
You shouldn't have lots of pressure inside the catch can
You should have something that withstands fairly high temps and can put up with nasty chemicals like motor oil
Your blog said
If your desire was bling, it really isn't very good bling as it looks now...
For the same money, here's a much better-engineered alternative to replace it: M7 Catch Can or you could go the $30 generic route.
...I removed the bottom drain plug and hardly anything came out.
Could just be a weak spot in the silicone. I'd be happy to replace it. Give me a call! It shouldn't be any big deal until you get the new one. Are you getting a lot of pressure in it? If so, check the coolant to make sure you don't have a head gasket problem - there would be oil in it.
Hope that helps!
Randy
Hope that helps!
Randy
As to a check valve, I'm not sure if there is one in these cans, or if they use the stock PCV valve, but there is a check-valve somewhere in the path to keep outside air from being sucked back into the crankcase. It lets blowby pressure out (and feeds it back into the intake) but doesn't let outside air back in.
The whole point of the PCV system is to release the dirty air that leaks by the valve seals and piston rings into the crankcase, without letting it get out into the atmosphere as pollution.
If the PCV valve sticks, then the pressure can't get out of the crankcase, and can, in the worst case, blow out the main seals on the crankshaft. Usually the hoses pop off the valve first, but there is always that chance...
Since it is emissions-related, the manufacturer is required by federal law to provide a five-year warantee on it, is my understanding, so I'd take it to the dealer to have it checked.
However, if it is a standard PCV valve as used on most cars, the simple answer is, remove it from the path, and try to blow through it then try to suck air through it. It is just a one-way check-valve, so it should allow you to do one but not the other if it is working correctly. Then it would be good to verify that it is not installed in the wrong direction, allowing outside air in, but not crankcase pressure out.
Hope that helps!
Randy
Hope that helps!
Randy
Alta have anything to say about this? PM Alta2 here on NAM... Everytime I have, I've gotten good response from them.
Any other record of bulging cans? This is the first I've seen.
Originally Posted by Wagnbat
I'm willing to bet Randy is correct. MDSBrain just got his baby back from the dealership with regards to a head gasket problem.
I am slightly confused as to how to check if there is pressure in the can. The bulged can is bulged when its in or out of the car. Would it of bulged from pressure and stretched the silicon?
Originally Posted by ALTA2
We will replace it also, Randy don't worry about. Most likely it is because the can is seeing boost(which it can take but not normal in the CC install) You might have something hooked up funny. How do you have it hooked up?
Edit: The can is hooked up however Randy installs it.
It it worth noting that silicone hose is not rated for containment of oil, gasoline, or toluene, all of which are present in a catch-can. It has little chemical resistance to these liquids.
By the time you change it, your oil will contain several percent gasoline, and if you ever use injector cleaner, it's a good way to get some toluene in there.
For lots more information read this report comparing hose materials...
Jeff,
I've got it taken care of, but thanks!
I spoke to the "brain" today, and we have figured out that it most likely was related to a head gasket issue he had. With that fixed, the pregnancy should be limited to the one time. We confirmed the vasectomy on his car!
Hope that helps!
Randy
Hope that helps!
Randy
Kimolaoha
07-05-2023 01:04 PM
Lschneider
08-21-2015 02:21 AM
M7Speed
08-06-2015 01:48 PM
