Cleaning the Intercooler Suggestions
Protecting the Intercooler
My solution to the bugs in the intercooler was to simply cut a piece of gray fiberglass window screen and slip it between the intercooler and the black cover. The screen blends right in and the bugs and other debris stay out. The only downside is that the airflow over the intercooler might be slightly reduced because of the screen.
Total cost of materials is $.50 and a trip to the hardware store Please stay away from the Big Box, Support your local Hardware Store. Time for cutting and installation ia about 5-10 minutes. Make sure you use the fiberglass, as the aluminum will probably abrade the fins. I have not had any problems with heat from the intercooler melting the screen.
Assuming that you are talking about cleaning the inside of the IC, not the outside, just about any solvent should do - all you are trying to do is wash out the oil that got into it - there should be little dirt.
If the outside is the issue, a some Simple Green and a garden hose should do the job...
bleonard1401
08-11-2015 02:53 PM
08-11-2015 09:01 AM
Ambient Thermal Management
08-07-2015 12:27 PM
