Transmission Q?
Old 02-12-2006 | 10:25 AM
NMgokart's Avatar
NMgokart
Transmission Q?
Starting to have difficulty getting the trans into reverse. (06 MC 5spd).
Seems to be only when cold. Sometimes the only way to get it to click in is to first rock the car forward in 1st, then retry reverse.
Anyone else having similar?
ETA: the car has 6100 miles and has just started doing this in the past week. Also getting some annoying high freq vibration thru the pedals.
Old 02-12-2006 | 10:54 AM
xtremepsionic's Avatar
xtremepsionic
Well you say there are some high frequency vibrations? Maybe something is wrong with your tranny.
Either way, try putting your Mini into 3rd gear, then put it in R. Works everytime for me, slides right into gear. You can actually use all the forward gears, I just find 3rd to be easiest to shove into
Old 02-12-2006 | 11:38 AM
fred3's Avatar
fred3
Pretty common problem from all the past posts on this. My '05 MC does the same thing, but with use I notice when it doesn't engage all the way now. When I feel that it isn't I just put it in first and disengage the clutch just enough to make it move. Then it goes into reverse easily. It's just the way it is. Nothing to worry about.
gknorr
12-26-2016 10:38 AM
vulkandino
10-31-2015 09:29 PM
SJ-R50
10-28-2015 09:39 AM
10-01-2015 01:13 PM
B1mm3r101
10-01-2015 07:22 AM
