Supercharger Tech. question
on
Are you considering a methanol blend in your fuel? The MINI's fuel injectors are well downstream of the supercharger. Air is the only thing going through the supercharger. The fuel is injected right at the cylinder head's intake port. (It is actually mounted in the intake manifold, but they are right at the very ends of the runners.)
Rawhyde
Rawhyde
on
Rawhyde
Rawhyde
Originally Posted by Johan
Not in the Fuel -- Johan
On a dragster, the carb sits atop the supercharger. The fuel/air mixture is compressed and blows straight into the intake ports.
On the MCS, the air flows out of the supercharger and up through the intercooler, then down through the throttle body before it goes into the intake mainfold.
Any liquids trying to make all those turns and twists will definately fall out of emulsion. It'll wind up puddling in the low spots and low pressure areas.
You may need to devise a method to inject it (in a fine mist) into the intake manifold.
What do you have up your sleeve?
Rawhyde
on
12-05-2016 06:31 PM
alistaircookie
10-08-2015 10:52 AM
08-25-2015 01:28 PM
