sway bars??
It depends. Unless you push it fairly hard around the corners, you might not notice a difference. You should probably search around the performance mods: suspension section of this site. You'll find a lot of info there. Rear swaybars really help balance the car out in corners. They can range from lessening understeer to causing all-out oversteer...depending on which size and setting. I'm happy with my H-Sport comp. It's not too hard to install. You need a jack, jackstands, some assorted wrenches, and a friend (or two). Go to Webb Motorsports and find the how-to on his forums.
I'd say that the rear sway bar and springs are the best suspension mods for your MINI... I highly suggest them. My MINI has not been the same since I installed the H-sport springs and ALTA sway bar. I put on the 19mm though... Now I want a bigger bar!!! I'm looking into the H-sport comp bar
The Webb Motorsports rear sway bar is the single best mod I have done to my car to date. It made an immediately noticable improvement my Mini's ability of to rotate around corners, made turn-in much more positive and quicker, and nearly eliminated the stock set up's tendency to understeer when pushed.
If I were doing it again a rear swaybar would actually be the very first mod I would make to a Mini, before (or at the same time as) a 15% supercharger pulley...
Originally Posted by foster200
does it affect the shocks at all, make for a rougher ride.. well rougher than it already is???
![LOL](https://www.northamericanmotoring.com/forums/images/smilies/lol.gif)
gar56
11-15-2016 06:41 AM
